Wiring
Mk1 vrs. Red wire with white tracer at position No9 on top of battery fuse box. Do any of you knowledgeable people know what this wire is for? It has chafed through completely. The owners manual states "not stated" thanks.
  • Sponsor
Which year was your vRS built?
#9 is shown in the dealer diagrams as "Not Assigned" ??
  • Sponsor
If it's a 10A fuse it's ABS related. As per this table from here:
@Wino has come up with similar info to what I've just found only with slightly different dates
<May 04 Not Assigned
May 04 > Oct 05 ABS/TCS/ESP
Oct 05 > Aircon
  • Sponsor
:thumbup:
If it's aircon (relay coil in fan control unit) it'll be red/lilac I think.
Depending on build date of the OP's car, your info may help to improve mine, Nige. :)
Edit: @nige8021 Your date info looks right to me, I think mine was based on the dates of the wiring pdfs as a whole, rather than delving within. Good work.
Edited by Wino
Fuse # 9 with Red with White tracer is the ABS
Fuse #9 with Red with Lilac tracer is Aircon
Great stuff thanks for the replies. It's an '05' fabia vrs and I do have an abs light illuminated. I'll repair the wire tomorrow and let you all know the result.  Again thanks.
The Red/White wire goes to pin 7 of the 38 pin connector on the ABS pump unit
This morning I stripped out the battery to gain access to the wire. Soldered the wire back together. ABS light is now OUT on the dash, speedo is working again as is the fuel gauge. Thanks for the advice. Anyone else having the same problem look at the red wire with white tracer on the battery fuse panel that rubs on the top rad hose clip. Thanks.
