Skoda Fixed price service
Air Conditioning + Brake fluid change £89.
Just booked at my local Skoda dealership garage.
Think it is good value, in case someone else would interested as well.
13 hours ago, silver1011 said:
Good price, should normally be...
Air Con - £75
Brake Fluid - £52
http://www.skoda.co.uk/owners/service-and-maintenance/simply-fixed
There is mention on the major/larger service that gearbox oil will be changed if required, that would make that very much a bargain as DSG oil change is about £180 on its own. Has something changed with Skoda fixed price menu pricing etc ?
Gearbox or DSG fluid change is never included in the Major Skoda or VW service fix price menu AFAIR. Check replenish is not change in SKODA VW language.
According to the two Skoda dealerships near me, the gearbox oil is considered 'sealed for life' and should never need changing.
This despite the fact I offered to pay for it to be changed ; "it doesn't need changed. Save your money!"
Almost all manufacturers claim auto gearbox oil is sealed for life.
Unfortunately 'life' for them is the length of the manufacturers warranty.
If you want your gearbox to last as long as possible then ignore the 'sealed for life' claim.
Any dealer that tells you to save your money should be avoided too.
Check / replenish isn't 'replace' unfortunately.
They are supposed to check the levels and top-up if required.
I'm not a betting man but I reckon it is rarely done.
Apologies to the OP, I don't mean to hijack the thread, but is changing the gearbox oil on an Octy Scout an easy job to do, one that a competent mechanic (standfast me!) could do?
If so, approximate cost  and what oil is recommended?
MTIA.
Gearbox really simple on the 6 spd, 17mm hex required.
Remove engine undertray on the scouts its steel so pretty heavy, Drain plug on the bottom and refill port on the side. Fill until it dribbles out and then refit plug.
Don't quote me on this but I think it takes 2.3 lts, the 5spd is 1.9 and is more of a faff as it has to be filled via the reverse switch.
The scout also has a transfer box at the front, drain point is easy to get to but refill has awkward access being above the right hand driveshaft.
I just get the oil from Skoda, right oil - latest specs  and not expensive.
Before someone else mentions it - remember the haldex oil and filter - no special tools required. I use a squirt can to refill.
Scott
Edited by smc998
Fin69, it's fine. The forum is for information sharing & owner's interests. Since now we focus on Gearbox, oil capacity etc, here are some information I found from another webpage.
 020:
G 060 726 A2 (Mk3 93-96)
G 500 000 (Mk3 97-99)
* capacity is 1.9 liters.
02A:
G 060 726 A2 (Corrado all, Passat B3&4 all)
G 005 100 A1 (Mk3 all- comment says "high performance gear oil" "SAE 75W-90API")
* capacity is listed as 2.0 liters for most transmissions, except the CTN, CDA, and CGN, which are listed with a capacity of 2.2 liters.
02B (only included because it's a very similar design, it's a slightly modified 02A for Eurovan):
G 060 726 A2 (Eurovan all)
* capacity is 2.5 liters.
02J (basically a Mk4 02A):
G 052 726 A2 (Mk4 Golf Brazilian built 00-02- comment says "SAE75W")
G 060 726 A2 (Mk4 Jetta 99-04, Mk4 Golf Brazilian built 03-05, New Beetle 98-05)
G 070 726 A2 (Mk5 Jetta 05-07- "31055>>12027", Mk4 Golf German built all, Mk4 Golf Brazilian built 05-07- "17055>>12027", New Beetle 06+)
G 052 512 A2 (Mk4 Jetta 07.5+- "13027>>", Mk4 Golf Brazilian built 07+, "13027>>" "CORRESPONDING NUMBER G 052 512 00" "API GL4 SAE75W")
* capacity is 2.0 liters.
0A4 (basically a Mk5 02J):
G 052 171 A2 (New Beetle all)
G 060 726 A2 (Mk5 Jetta early 05- ">>30105")
G 070 726 A2 (Mk5 Jetta 05-07- "01115>>30017", Mk5 Rabbit/GTI all, Mk6 Jetta all)
G 052 512 A2 (Mk5 Jetta 07.5+- "01027>>", Mk6 Golf all)
*capacity is 1.9 liters.
02S (6 speed 02A/02J/0A4-style transmission for Mk6):
G 052 512 A2 (Mk6 Golf all)
*capacity is listed as 2.3 liters (KWB, MCB), or 2.1 liters (KVT, MUE).
0AF (not sure what transmission design this is):
G 052 512 A2 (Mk6 Golf all, Mk6 Jetta NNL code)
G 060 726 A2 (Mk6 Jetta LDZ code)
0AH (another unknown Mk6 transmission, might be similar to 0AF):
0AJ (another unknown Mk6 transmission):
G 052 171 A2 (Mk6 Golf all, Mk6 Jetta 2011-2013- ">>30.06.2013")
G 052 527 A2 (Mk6 Jetta 2014+- "01.07.2013>>" "high performance gear oil")
G 060 726 A2 (Mk6 Jetta LHY/LNY code)
*capacity is 2.0 liters.
02M (listed for comparison, and GAP sells this fluid for Mk5 0A4s as an "upgrade"):
G 052 171 A2 (Mk4 all)
* capacity is 2.6 liters for R32, may be different for FWD models.
02Q (listed for comparison, basically a Mk5 02M, and GAP sells this fluid for Mk5s as an "upgrade"):
G 052 171 A2 (Mk5 all, Mk6 Jetta early 2011 ">>29.05.2011")
G 052 512 A2 (Mk6 Jetta 2011.5+ "30.05.2011>>")
* capacity is 2.3 liters.
Edited by yczouwei
