Engine rattle 1.4tsi
Hi everyone,
Brand new user so please bear with me.
I have just started getting this rattle from the engine today and i am worried its the timing chain. I wonder if any of you can identify it.
The engine is 1.4tsi 125 in a 62 plate octavia.
As a bit of background, for the last month or so the engine has been slowly losing coolant and i was going to put it in the garage to get that rectified next month. Is there any chance the two are related?
Thanks in advance!
:)20170325_150324_2.mp4
Noisey water pump bearing, and with the coolant loss my guess is thats where the leak is as well, i would book it in sooner rather then later; as this could lead to the vehicle overheating which may cause more damage then just a water pump.
Thanks, was thinking along those lines with the fluid loss. :)
NB The water is on an aux belt not the cam chain
 I had exactly the same problem last week on my 1.4TSi 122hp.
A "rattle" coming from the rh side of the engine (looking from the drivers seat). Took it into the local specialist and they diagnosed a water pump bearing failure and sorted it the same day... :)  not had the bill yet but seeing as it was sorted in half a day I am hoping it is not too bad...
Quick update. Noise was the water pump on its last legs. Thanks guys.
