TALEX Speed Detector
Yep the ciggie lighters are on all the time even on the mk2 just take a live feed of the aircon maybe vrstu could give you some pics when he installs his:thumbup: .
any update?
  • Replies 78
  • Views 7.9k
  • One would hope that the big RED light would alert you to these :P (and if it's your normal practice to ignore them unless there's a camera there then :thumbdwn: :nono: )
Oddly enough - yes!!
Installed mine on Sunday, ran a power cable directly from the fuse box, accross the top of the dash pod and out of the small sensor on top of the dash.
sounds neat! any photos - in particular the fuse box wiring? can i ask when taking power from the fusebox is any soldering involved at all or do the wires just clip on or similar?
cheers
No great photo's tbh.
Look in the fuse box and there is a spare fuse with a switched live marked for the phone. You'll ideally need to remove the fusebox but that's only two screws, release a small latch inside and slide the whole 'purple' bit down slightly to allow you to enter the new wire. (Use the yellow repair wires with termination fitted)
