2.0tdi CR dmf & clutch torque specs?
Tried a few searches but nothing concrete - can't access erwin atm for I suspect ip address and cc address conflict / check or I'm doing something stupid - tried 3 valid cards :-(
FL 2.0tdi Cr manual best I've found is  DMF to crank 60nm & 90 degree, I need the self adjusting clutch plate too please - Luk if it makes a difference - sachs one ruined the bell housing :-(
Would like to put it all back together over the weekend after a 4 week search for a replacement box - I'll eventually repair the original.
Thanks, Steve
The Clutch pressure plate 13 Nm M7=20 Nm. For a luk clutch you will need a self adjusting clutch tool to align and set the clutch cover
