Hard wired USB charger
DIY Brodit holder. I like it.
You know you can buy a Bluetooth dongle with 3.5mm jack plug that plugs into the Aux jack in the centre console for a fiver don't you?
Yeah, but then I don't get the microphone option, which is something I would use. Please, they need charging or batteries changing. Sometimes hidden wires are the simplest option :biggrin:.
You do get the mic option it uses your phones mic, but yes they do need charging from time to time although I found about once a month and you already have the usb charger there.
I like that holder, nice work fella. Same phone as me, too
Nice work but you need to put a smaller fuse in as 10amp is too high and the damage will be done way before it blows. Try a 3 or 5 amp.
Good plan! The USB charger can pull 3 amps so I'll go for a 5 in that case.
Quick update, I received the mic, splitter and extra aux cable, tore my dash and centre console to pieces resulting in this!
