Engine Fans Running Constantly when Engine Running
On 08/04/2020 at 17:31, Tezza2020 said:
Hi. I have a 2011 Octavia combi 1.6 tdi and the cooling fan comes on when the engine is cold, and stays on for a while, and this is causing vibration through the steering wheel.
I've just changed the coolant temperature sensor, as it was suggested that it could be that, but the issue is still there.
So after reading this. I was wondering if it could be that!
If anyone could offer any advice, it would be much appreciated.  I've also looked on the net about changing this yourself and it seems you can, but I'd like to know for sure if that's true or not.
Many thanks
Hi there.  Did you solve this problem mate as I'm having the same issue on my one,  same year same engine.
Hi. Have you had a diagnostic scan done?
Yes and it doesn't shows nothing.
20 hours ago, Zafirov said:
Hi there.  Did you solve this?
I have the same problem on my one,  same year same engine.
Mine had 01598 code. Battery open circuit. Which turned out to be a bad earth
