ABS Warning light
  • Replies 78
  • Views 48.3k
  • Look what happened when I started removing the tape from the black wire......PS I applied very little pressure :-   removed the rest of the tape and look at this mess.....
  • Well, these are usually a failed wheel sensor or break in the associated wiring, so you actually need VCDS or similar for diagnosis. VCDS Lite and a good OBD2 to USB cable are cheaper than a garage ch
  • sepulchrave
    sepulchrave
    When you put it back on give it a quick blast of WD40, helps it snap back into place, helps keep the water out and makes it much easier to take it off again in the future.
Yeah I get mine from them. If you have bought those white ones they are the wrong ones. They are Mk2 Fabia ones.
Edited by TMB
21 hours ago, TMB said:
Yeah I get mine from them. Mine are green though.
Thanks Lee. It was too late to cancel the order for the white ones, but they only cost £2.79.
