Gearbox ID
Guys I have a 2011 1.2 Tsi DSG Fabia estate in that the DMF exploded wrecking the gearbox so I need to locate a box. Could anyone decipher the codes from the sticker/handbook or point me to a gearbox ID as i am struggling to work out gearbox types.
Why they put a DMF on a 1.2 petrol is beyond me.
I presume it is a 5 speed with the semi auto set up,cheers. I presume it is the NBD but is that all I need cheers.
NBD  from that VIN Sticker.
If it is a DSG it is a DQ200 7 Speed Twin Dry Clutch DSG.
Why do you think it is a 5 speed semi automatic,
have you not driven it and seen when you put it in 'D' that it has, 1,2,3,4.5,6,7 show as it goes up the gears.
Edited by Awayoffski
Oh right I have had nothing to do with these I priced a clutch and flywheel up from our local factors as it looks like the dmf has dropped to bits and cracked the box! I presume it is not what i would class as a "conventional" clutch? Sorry for my ignorance just never played with these before. It looked from the outside like the Vauxhall "semi auto" set up but i must be wrong.
No clutch packs and very specialist repair job,
or finding a used DSG that is fault free.
Just an idea of a similar box and changing clutch packs.
