Rear view camera retrofitted to SII L&K
Camera part nr. 5N0827566
Control unit nr. 3AE907441
Your parts seem to be ok.
I have low camera installed, so no guidelines anyway.
It must be coding - try to search the web.
  • Replies 52
  • Views 12.4k
  • I took the driver's seat off to get to the cable loom. The seat is held with 4 large Torx. To get to the loom you have to remove the phone controller and unclip the driver's seat electrics.
  • Calibration done. It had to be done with the calibration grid, otherwise the RVC STG would simply return an error message. I printed the grid as a poster and pieced the sheets together.
  • The handle will fit without the bracket. It has small plastic "hooks". Make sure you rust proof the cutout in the tailgate and then use a thin film of silicone.
It was too easy! :D If I tried my camera then boot was opened. Guidelines appears only when boot is closed. Now i have everything OK, Thank you all who helped me.
  • 9 months later...
I want this mod, but don't fancy doing it. Anyone know anywhere that does this as a paid service to have camera and the existing TV tuner working in an L&K mk2 Superb estate?
I'm in Preston but do travel about.
