Adjust volume of side parking sensors?
My 2015 O3 has the Park Assist with 12 parking sensors - 4 front, 4 rear and 4 side.
Is there a way to reduce the volume of the warning tone from the side sensors ONLY leaving the front and rear sensors at normal volume?
My wife finds the volume from the side sensors too loud and distracting when parking in a normal car park - and the alternating two tone warning when you are close is VERY distracting.
I can't see anything in the adaptation channels of the 10 Park Assist module, but is there a coding change possible?
;SW:5Q0-919-298-F   HW:5Q0-919-298 ---  Park/Steer Assist
;Component:PARKHILFE PLA H12 0047, Coding:0131061041
;EV_EPHVA2CAU3700000,003019,EV_EPHVA2CAU3700000_003_VW37.rod
;Wednesday,05,October,2016,11:33:57:40444
;VCDS Version: Release 16.8.2  Data version: 20160926 DS261.0
;VCID: 42C88AE6D5122D52E2-8016
IDE00001-Production mode,Deactivating
IDE00845-Wheel circ.,1960 mm
IDE01165-Park assist activation tone,On
IDE01169-Audio reduction request,On
IDE02328-Distance to curb,15 cm
IDE02329-Allowance for vehicle fittings (width),0 cm
IDE02332-Deactivate production mode,0
IDE02333-Allowance for vehicle fittings (length),0 cm
IDE03782-Switch-off speed for parking assist,15 km/h
IDE03783-Switch-on speed for parallel parking assist,37 km/h
IDE04159-Deactivation of start-stop function,Start-stop function in control module active
MAS01426-Speaker volume for rear park assist,Stage 6
MAS01427-Speaker frequency for rear park assist,Stage 3
MAS01428-Speaker volume for front park assist,Stage 5
MAS01429-Speaker frequency for front park assist,Stage 6
I'm sure you can do this on the touch sceen.
Press the Car button, then settings, then parking & manoeuvring.
Have a play about!
Have a play about!
You can certainly do it for the front and rear, not sure about the side?
You cannot do it for the side - as far as I can see there are no adaptation channels in module 10 about the side sensors and nothing appears in the infotainment screen (and there are no adaptation channels in module 5F to add them to the infotainment menu).
Definitely NOTHING in the infotainment screen about the volume or tone of the side sensors... checked when I got home yesterday.
Any other thoughts/suggestions welcomed.
