Polisher help
Hi
May be lucky enough to receive a polisher as a gift, I have browsed ebay and amazon and I think i have found one that suits me
http://m.ebay.co.uk/itm/Dodo-Juice-Buff-Daddy-Das-6-Orbital-Machine-Polisher-Free-Supernatural-Sealant-/311101855761?hash=item486f1d9811%3Ag%3AJbcAAOSw8GtZO8jp&_trkparms=pageci%3Afea8285a-795a-11e7-a405-74dbd180f7cc%7Cparentrq%3Aaf20a4a915d0a888e8a78249fffffc6d%7Ciid%3A8
Is this polisher
1)safe to use and wont strip paint
2) Powerful enough to remove swirls
3) If anyone has one would they recommend it?
Sorry if the questions are a bit daft or they made you loose braincells but i have never used nor had a polisher
1, yes
2, yes
3, I use a das 6 pro for 3" work and its a great little machine that's very similar to this
it'll do the job, I would opt for the das6pro as It has a bigger motor so wont get bogged down as easy.
pretty much impossible to damage paint with a DA but it can be done, I was do some reading if you're unsure on how to use one.
best practice I did before using it on my car, brought a old bonnet from the scrap yard and went to town on that.
bit of advice, start with the lowest abrasive compound and work up to removing the swirls
Thanks for the replies, definitely taught me something ill do more reading about it and then ill purchase it
On ‎8‎/‎7‎/‎2017 at 12:27, RobLarby said:
1, yes
2, yes
Hey Rob. Did you need to change the counterweight on your m/c when down sizing the size of you backing plate ?
Thanks .
Thanks .
No I just changed the backing plate and it runs perfectly fine
That's good to know Rob. I'm Waiting for a 3.5" backing plate (as well as some other goodies) to arrive from polished bliss and was hoping I could get by with the original counterweight.  I have heard some people reporting that excessive vibration is common. Fingers crossed.
