OBD errors
Hey!
I have today connect my car to computer...and have this errors..
 Car: Skoda Octavia
    Year: 2014
    Engine: CKFC
    Mileage: 173000 KM
02 Transmission
    Trouble codes:
        P072C00 - Stuck in Gear 1
            Intermittent
        P072D00 - Stuck in Gear 2
            Intermittent
        P072E00 - Stuck in Gear 3
            Intermittent
        P072F00 - Stuck in Gear 4
            Intermittent
        P073A00 - Stuck in Gear 5
            Intermittent
        P072B00 - Stuck in Reverse
            Intermittent
        P174A00 - Partial transm. 1 valve 3 Electrical error
            Intermittent
        P174E00 - Partial transm. 2 valve 3 Electrical error
            Intermittent
        P079700 - Pressure Contr.Solenoid C Stuck On
            Intermittent
        P179D00 - Cooling oil valve Electrical error
            Intermittent
        P173400 - Starter release from the selector lever sensor system
            Intermittent
Car go normaly.....
Whats wrong?
Pleas help
well, cannot answer what goes wrong, but the fact they are intermittent means that they did not "stick" - in practice, they might have only happened a couple of times.
Those transmission valve errors should probably be a good starting point to investigate the root cause for all the others.
Was the car stopped for a long time or starting from a very cold weather at some point? I would just clean the errors, drive it for a while and see if they return.
2 hours ago, Skodilakrs1 said:
Hey!
 Car: Skoda Octavia
    Year: 2014
    Engine: CKFC
    Mileage: 173000 KM
02 Transmission
    Trouble codes:
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
Car go normaly.....
Whats wrong?
Pleas help
Was your car "on" when you ran the scan. I saw similar errors once and I think on reflection my engine was on but start stop was active which made me forget it was "on". Clear the codes, re-scan with only ignition on.
Yes it vas on. OK will doo.
jaco2k
No,nothing.
Ok.
Thanx
You could be having this:
Nothing shows up..
Today when i come from work,i scan car...and was the same errors  there....**** what now? Dsg say...good bay...?  When i scan car i didnt turn of car i have do scan imediatly when come home-engine on.
UPDATE: I delete errors...go drive...com back...shut engine down...add just a contact,and scan again-No errors. Then have turn engine on...go just a little foward and back-then scan-engine on..all errors are ther again.
And now i can confirm that there are no errors when i turn engine of and do just contact...so go driving...coming home...turn engine of and do just contact...scan...no errors. And nov...go driving...come back and do the scan vith engine on..there are errors...
Trying this..turn engine on...driving little foward and back...engine running..scan..errors are there...and nov engine on little foward and back...engine of..turn just contact...no errors:)
I think with the car ist nothing wrong...
Edited by Skodilakrs1
Most errors are gone when the engine is off, however some errors may persist, and it was like that on my car. The worse is that the dealer still didnt see those errors (that odbeleven had). They saw one error, replaced the shifter, but this error is still there:
Trouble codes:
            Intermittent
This error obdeleven see when  scan vith engine off...thats ok. Start engine and do the scan this error will no show. Its becous engine is of.
Actually I get more errors with engine on. But some errors persists even with engine off.
  • 4 weeks later...
Always do the OBD scan with the IGNITION ON, but engine NOT running.  This is important.
I forgot this a few times when I first started scanning with my OBD11, and it would throw up similar random transmission errors like yours.
Clear the codes - turn ignition off, disconnect OBD, wait a few seconds, re-connect OBD, turn ignition on ONLY, but do not start the engine.  Then re-scan.
Hopefully, you won't have any of these errors.
Tell us how you go?
Yes, I do that way already. However some errors still persist after engine off.
Too much technical knowledge a bad thing!!
