2012 Monte Carlo standard parts
Clearing out the garage since it's longer over due. Everything listed will need to be sold or will go to the tip / weighed in for scrap.
Full set of Monte Carlo suspension, should be 10/15/20mm (not exactly sure) lower than standard Fabia suspension. Included is 4 shockers, 4 springs and various extras like top mounts and bearings. - £60
Full FMIC and pipework, low mileage so good condition. - £100
Will update with more things later / tomorrow and will add pictures
Hutchy that suspension will fit a mk1 won't it?  On Euro the part number for standard suspension on my elegance and a mk1 is the same so I would assume so.
Yep, should fit the mk1
can you fit it? :)
Not at the minute, I'm chocka and just want rid of everything for the space. I'll be sure to sort you a deal if you want them though.
Her car is sitting on its arse, must be about a 50mm drop, which on standard shocks is nuts.  Want to lift it a bit closer to stock.  I'll speak to her and see what she says.
Edited by Jaspire
spelling
Yeah of course, no worries.
I can fit the rears but fronts will be a chew for me. Just let me know if you do want them and i'll keep them to one side or somthing
Just found a full standard set up in the garage that came off of mine, forgot all about it.  Fk me I'm getting old. Probably need different rear springs as it's off an estate, but it's better than nowt. Forgot Brimma had left the original suspension in the boot when I bought it.  Free bump anyway!.
FMIC for a mk1 vrs?
10 hours ago, Stewpotz said:
FMIC for a mk1 vrs?
Be more trouble than it's worth trying to fits mk1 I'm afraid.
