Superb MK 2 - 1.8 TSi Incorrectly Coded
Hello Everyone,
i just picked up a Skoda Superb MK 2 a week before. The car seems fine, nothing wrong. Thought a VCDS Scan would be safe. Here are the result.
May i know how to fix these, I am new to all this.
Saturday,02,September,2017,08:22:54:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS667.2
www.Ross-Tech.com
VIN: TMBBBG3T7BA301897   License Plate:
Mileage: 57500km-35728mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 42 44 46 4C 52 55 56 62 72
          77
VIN: TMBBBG3T7BA301897   Mileage: 57500km-35728miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0010
   Revision: AAH17---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 33361 790 00081
   VCID: 3566FA965CDA36E90A-8060
1 Fault Found:
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 57415 km
                    Time Indication: 0
                    Date: 2012.01.17
                    Time: 16:36:44
             Freeze Frame:
                    RPM: 850 /min
                    Load: 19.6 %
                    Speed: 0.0 km/h
                    Temperature: 94.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 890.0 mbar
                    Voltage: 13.589 V
Readiness: 0010 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 863D6016092200FB611306EB90200081350C00
   VCID: 7AFC29AAF5441991A7-802E
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000001002
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 020C514A95945151FF-8056
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AE
   Coding: 48990A27E85BF1C0C0080081110089EC47F000AE73208960640040000040
   VCID: 3E74E5BAA9ECF5B1DB-806A
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13051  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 110510 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 214
                    Mileage: 57467 km
                    Time Indication: 0
                    Date: 2012.01.18
                    Time: 19:33:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 C    HW: 1Z0 919 475 A
   Component: PARKHILFE 8K  H06 0006
   Revision: --------    Serial number: 66541011207762
   Coding: 100004
   VCID: 418E9E46D8128A49A6-8014
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 B    HW: 3T0 959 655 B
   Component: J234__LD7 VW10 HI   1916
   Revision: 19014000    Serial number: 003GRP8RP9T/
   Coding: 0017463
   VCID: 40889B4213188341A9-8014
   Subsystem 1 - Serial number: 6332MTS605341200
   Subsystem 2 - Serial number: 6342MTS622691130
   Subsystem 3 - Serial number: 6351HTS6TFKLA6KJ
   Subsystem 4 - Serial number: 6361HTS6IUMLA6KR
   Subsystem 5 - Serial number: 63727TS6HVNV79KJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100529100367
   Coding: 008A140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 76E43D9AC95C7DF1C3-8022
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 841 G    HW: 3T2 920 841 G
   Component: KOMBI         H04 0406
   Coding: 110F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3878F3A283C8CB8111-806C
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 130510F2000758
   Coding: E9A1FF0600060200003303
   VCID: 6DD612F6740ABE2932-8038
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 57467 km
                    Time Indication: 0
                    Date: 2012.01.18
                    Time: 19:41:36
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0406
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADC19EA8DE4A91157-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EC018A6D3461D1EF-8026
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 C    HW: 8X0 959 793 C
   Component: TSG FA        H09 0409
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 4D96B276144A5E2952-8018
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 316ECE86A8B21AC956-8064
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 C    HW: 8X0 959 792 C
   Component: TSG BF        H09 0409
   VCID: 4C90BF72EF50572145-8018
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1377095
   Shop #: WSC 06821 002 1048576
   VCID: 3460C79257A02FE13D-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 C    HW: 3T0 035 156 C
   Component: BOLERO        013 0029
   Revision: -----27S    Serial number: SKZ4Z3K1101617
   Coding: 0D0004000004
   VCID: 2E54D5FA798C05314B-807A
1 Fault Found:
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 57500 km
                    Time Indication: 0
                    Date: 2012.01.24
                    Time: 09:16:45
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
   VCID: 4E94B57A194C65312B-801A
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H06 0409
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668097028
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 326CC18A65B421D12F-8066
End-------------------------(Elapsed Time: 03:20)--------------------------
Edited by simannjo
Thank You. This worked perfectly.
How ever the only fault now is the LED's at the number Plate light.
That problem can simply be solved by refitting the original bulbs...
Looks like you've already coded the car for LED licence plate. What bulbs have you fitted?
I just picked it up and tried VCDS for the first time. Seems like the leds dint like my car they still show a bulb blown light. I don't know how i can fix this. I am planning to have the entire car on LEDs only.
That beats the purpose having Leds.
Was coded by the previous owner.
Ah, now things are getting interesting. What is the purpose of using LED's as license plate lights? After seven years of following many Skoda forums I haven't found any advantages, but can only make a long list of disadvantages:
  • The LED's generate broken bulb errors.
  • To work around these errors, fiddling with extra resistors is needed.
  • To mount these resistors, the original wiring has to be cut, reducing long-term reliability.
  • As a result of these resistors the power consumption is even higher than with the original bulbs.
  • The LED's are much more expensive than the original bulbs.
  • The illumination pattern is generally worse than the original bulbs.
  • The color of the LED's is mostly much too blue, usually around 6000K, where the original bulbs are around 2500K or lower.
It depends what you fit - rather than using an LED festoon bulb in the original holder, I replaced the entire unit and coded my Octavia to suit.
- No bulb errors
- No load resistors (were supplied but not needed)
- No changes to original wiring (have the same connector as the originals)
- Lower power consumption
- Yes, more expensive than halogens at about ~£13 for the pair.
- Illumination pattern is perfectly acceptable. No hotspots or striping
- Not sure mine as 6000K but certainly are whiter than standard
Personally, I think halogen lighting looks dated now even if it's perfectly functional...
As to the OP, it sounds light the original owner has fitted some cheap nasty LED's. There are complete units on eBay for ~£20 that might be suitable but please check as I'm not 100% sure which are needed.
