Roomster lower dash removal
Looking to change the rear brake switch shortly, Have understood the excellent access procedure posted for a Fabia, but the roomster lower dash looks a bit different. Which screws  and panels need to be removed to get access to the switch.
Regards,Roger
hello
  i didnt need to remove anything when I replaced mine
Hi wallabean, thanks for your comment. The only electrical connection i can see in the upper brake pedal area is on the throttle pedal which i took as a throttle sensor. Is this where you found the brake switch?. I was assuming i needed to go further up into the dash to find it and thus remove some lower dash. interested in where you found it.
