Mk2 fl octavia vrs fogs
Just woundering if you turn on cornering fogs does it affect the drls?
The fogs and DRL are separate on a FL MK2, why would you expect changing one to cause issues with the other?
If done correctly, cornering fogs should have no effect on the DRL.
If someone has coded it badly then anything is possible of course :)
I have cornering fogs activated on my vRS and I can confirm that they have no effect on the DRL's
The cornering fogs only operate when your headlights are on.
when my headlights are on my DRL's are dimmer ( not sure what % they are set to) but still on exactly as they were prior to having the cornering fogs activated.
I'm trying to make my factory led DRLs make run all the time , even when I manually turn light switch right ( low beam on ). At the moment as soon as it gets dark or I turn the switch my low beam xenons come on and DRLs turn completely off. Greetings
The default seting in side light mode for the DRL's is 35%.
* Other brightness % are available *
Thanks @Auric Goldfinger I knew someone would know the default %
