Dome lights not working, when doors are working
Hi all, I had my 05 Skoda Superb for over a year and one electrical issue bugged me a lot. Dome light and wing mirror lights are not working when doors are opened. How can I fix this problem. I fixed water ingress problem, resoldered all connections under a carpet. And still noting.
P.S. dome light works, when turned on manualy, wing mirror lights are good to (accidentaly damaged wire that goes to driver side wing mirror light) , all wing mirror lits and all dome lights came on.
Can any one help me with this promlem?
On 2017-09-29 at 11:39, gfinneran said:
Micro switch in the door lock not working, are you getting a door open indication on the dash display for any of the doors when opened?
http://www.taligentx.com/passat/maintenance/doorlockmechanism/
I think microswitch is working, because I get an indication on the maxidot display if any doors are open. And I know, that wing mirror lights are OK.
  • 11 months later...
hi did the problem solve.I am facing the same problem
