Inlet manifold
Does any one know where to get an inlet manifold fold a 12 plate 2.0 tsi.
Just rang the stealers £293 + the dreaded  vat.
Noticed they are cheap in the states but how do i find the right paet number?
Try TPS, or possibly GSF car parts?
Mine just arrived from US eBay. Paid about £120 all in (though not fitted it yet, so don't know 100% if it fits!)
Keep us informed. Hope it all fits
Tps same price as the stealers
Does the new manifold need programming in after replacement?
Highly unlikely. There is a vavuum actuator and solenoid, mechanical intake tract runners and a position sensor?
Has your inlet manifold 100% failed? I've a runner sensor, solenoid, and vacuum actuator available if you wanted them before splashing out?
Thats great. Although i have already splashed on a new manifold! Cheers anyway
Hope your problem is sorted
Edited by mk2octavia
I bought one of ebay for £128. Dont think it will work though no sensors came with it
Just transfer the sensors from your old one, or like I say, I have them going cheap :)
Is it a genuine one from US? I didn't think they supply them other than fully assembled with sensors. Problem is, sensors could have been faulty on your old one if you are getting DTCs / engine light.  Does it have the runner control solenoid and mechanism?
No its a non genuine one off ebay. Thought i could get away with it. I have been getting dtc of p2015.
It has the runners and an arm externaly that control it and a peice of rubber house. But cant see any thing electronic.
This is the item i have bought.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F172946113145
How cheap and do they work?
It looks genuine and has the vacuum actuator, but new parts come with the sensor, solenoid etc. too.
Edited by planehazza
Cheap, just sat in storage. They work, and the reason I had the p1505 was due to the runners being all gunked up.
Check the ebay link in my sig.
Sorry im on my phone.  No link in sig
OP: it is a bit of tricky situation.  The solenoid or sensors can fail and generally not readily available separately. Maybe you could try to match a part but a dealer doesn't offer them.
 Can you return the manifold for refund and if you must try to source a genuine replacement from US, like Deutsche Autoparts may ship international.  If you do some fault finding on your IM and pin point, then you could consider a different course of action.
Personally, with no experience of that pattern part, I am not sure I would go to the trouble of fitting myself.
If you don't have system lean faults then it is probably one of 3 or 4 things.
1) actualor solenoid
2) position sensor
3) either wear and hyperextension on the runner movement (can't really see without removing manifold) or gunked up runner movement (again have to remove manifold).
2) position sensor
I will return and just buy one from the stealers i think. No point replacing it if its the sensors/solenoids that are faulty.
Looking in the states they work out about £280 with shipping
