Headlight beam
Hey guys, I want adjust my head light beam. I got the lamps replaced and after that one goes way up and other goes way down. It gets worse when I am on High beam. Can anyone help from where I can adjust the headlight beam?
As I see the been has been confused a lot, you'll better have it done in an electrician or tech who have the appropriate beam aligning equipment thus adjusting the proper and right way.
It's nut an easy thing now to do it yourself as you may set it up higher our lower and again facing problems..
Would recommend someone with VCDS if you have Xenons. Otherwise, feel free to attempt this yourself - plenty of videos on youtube about this... You just need some basic tools and a flat level ground with a 90 degree wall you could test on.
Ask a technician if you have Xenons as you risk braking the mechanism if you don't electronically set them to the "Adjusting position".
