park assist advice required please
i bought an octavia vrs 2012 ,it was an unmarked police car
when i got it the stereo didnt work and had no gps aerial,aerial now installed and radio coded to the car ,so music and sat nav now work
however i have never had any joy with park assist ,nothing on the stereo screen when going into reverse ,no beeps at all
reversing lights work ok when engaged and i can hear all of the sensors clicking in the rear bumper
the speaker is still connected in the b pillar trim with no signs of any damaged cables
not sure where to look now ?
could the park assist be not activated in the dash display ?
 i had vcds test  and it reported park assist speaker ,so is it possible this speaker is not working and would knock out the whole system ?
any advice most welcome
thanks guys
thanks guys
Yes, the speaker can knock out the whole system.
My Octavia had the same problem. It was a faulty speaker behind the passengers side B pillar.
The park assist can be turned off from the stereo, however, if you put your car in reverse, the sensors should still beep if you go close to something.
hi guys
this is the full scan
plenty of other problems ,these are the stored codes before clearing so hopefully some will be gone
should just leave light issues and park assist
light issues are BIB altering wiring for their blues ,so need to sort that out by chasing cut wiring etc
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBEF21Z9C2093140   Mileage: 172910km-107441miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: AAH18---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 40918 001 1048576
   VCID: 79FE5AD9304EAC8ED6-802C
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 163B601C092B00FD680C06E890190081340800
   Shop #: WSC 73430 790 00074
   VCID: 79FE5AD9F04EAC8ED6-802C
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CF043CDF77C99A6CD-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8A05BB1C040080080110001E4430000AE524D8960808440040040
   Shop #: WSC 49502 001 1048576
   VCID: 3F8AF4C1AEEA42BEA8-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 14101  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
8 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 62
                    Reset counter: 53
                    Mileage: 172504 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 07:30:36
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 125
                    Reset counter: 15
                    Mileage: 172503 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 07:30:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.05 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
             Freeze Frame:
                    Fault Priority: 4
                    Reset counter: 15
                    Mileage: 172503 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 07:30:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.05 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03156 - Sensor for Anti-Theft System (G578)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 29
                    Mileage: 172509 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 20:51:52
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.45 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 20
                    Mileage: 172538 km
                    Time Indication: 0
                    Date: 2017.11.05
                    Time: 12:09:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00984 - Left Tail Light (M4)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 47
                    Mileage: 172538 km
                    Time Indication: 0
                    Date: 2017.11.05
                    Time: 12:15:31
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 172538 km
                    Time Indication: 0
                    Date: 2017.11.05
                    Time: 12:18:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 172919 km
                    Time Indication: 0
                    Date: 2017.12.03
                    Time: 15:19:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901129702798
   Coding: 10800F
   Shop #: WSC 13765 790 00074
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 3362A8F19AA296DE5C-8066
1 Fault Found:
1080340 - Parking Aid Speaker
          B107C 14 [009] - Open or Short to Ground
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 172503 km
                    Date: 2017.10.30
                    Time: 07:22:44
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC28ASX0
   Coding: 0020788
   VCID: 3D768EC964E650AEBA-8068
   Subsystem 1 - Serial number: 6332MSME6434581DF
   Subsystem 2 - Serial number: 6342MSME65411A1EE
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20111107800704
   Coding: 5080140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77FA5CE1CE5ABAFEA0-8022
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 R    HW: 1Z0 920 943 R
   Component: KOMBI         H04 0607
   Serial number: 00000000000000
   Coding: 410A01
   Shop #: WSC 73430 031 00074
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 4898EF1DF324050619-801C
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 021111F2002926
   Coding: 351303
   VCID: 3A7C85D5B5C867969F-806E
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADC75958DE817162F-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 E    HW: 3T0 035 680 E
   Component: RNS-MID       H61 3984
   Revision: AB001001    Serial number: SKZ6Z7L4305067
   Coding: 04000402000100810000
   Shop #: WSC 73430 790 00097
   VCID: 326CADF56DB89FD657-8066
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 31
                    Reset counter: 19
                    Mileage: 172496 km
                    Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 13
                    Reset counter: 54
                    Mileage: 172503 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 07:22:58
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0000756
   VCID: 4898EF1D3B24050619-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
   Revision: 00H22000
   Shop #: WSC 26052 210 125136
   VCID: 397E9AD970CE6C8E96-806C
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479AEC21363A0A7E10-8012
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 31
                    Reset counter: 19
                    Mileage: 172496 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 13
                    Reset counter: 54
                    Mileage: 172503 km
                    Time Indication: 0
                    Date: 2017.10.30
                    Time: 07:22:58
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012554
   VCID: 326CADF5ADB89FD657-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3362A8F152A296DE5C-8066
End-------------------------(Elapsed Time: 02:25)--------------------------
Sent from Mail for Windows 10
update
all my reverse parking sensors are clicking when in reverse but i get no sound at all ,nothing is showing on my stereo
i have just installed a new parking buzzer and it is still the same nothing is working
any ideas guys ,would it be disabled anywhere ?
thanks
Well looking at your autoscan > Address 10 as shown below it is showing a error with Speaker, 'Open or short to ground' which suggest there is a broken wire for the speaker. It will be better to trace the wire and see if you can identify where it may be broken? Also get yourself a multimeter to test the wiring. You should be able to quickly rule out power not getting to the speaker when park aid is active.
Sorry but seems like you have a long way to go in order to fix the wiring issues you have in address 09 :(
   Coding: 10800F
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 172503 km
                    Date: 2017.10.30
                    Time: 07:22:44
Edited by singh946
