Rear windscreen washer
not squirting owt. No signs of leaks - front washer bottle has juice in - is there a rear bottle or d'ya reckon I'm blocked up?
was that what it was, Sean?
I am having the same problem on mine. Have looked in boot but cannot see, feel any puddle of water under CD changer. Will try the old trick of sticking a needle down the jet to see if there is any blockage. failing that will try and work tube off to see if there is any flow from there. If not I am stumped and will have to investigate further. Has anyone else had same problem but not related to tube coming off???
I have this prob too - and i have water under/around the cd changer in the boot. I cant get the carpet up enough t o get under the cd changer (i assume this is where the pipe connection is?) - so do i have to remove the cd changer to get access to the plug? if so, how is it fixed? thanks!
I believe that the carpet (trim) in question is behind not under the CD changer.
The pipe connection is on the n/s/r wheel arch.
