Heater Blower not responding.
Hi folks. The heater blower on my ‘13 Superb has stopped working. The Climatronic panel still lights up and I can still direct the heat. However the blower won’t change the intensity of the air. And of course in this cold weather, I’m not getting any air into the side windows. I can still use the temperature adjustment and also the quick clear windscreen button. I’ve changed the 40amp fuse but doesn’t seeem to have made a difference. Any other ideas? TIA
Remove it and test it. Replace if necessary.
can be taken out without removing the glove box but its quite tight
Edited by SuperbTWM
Give it a kick from underneath this usually get its started but as others have said on here the bushes will be going and will eventually need replaced
Not to dear from ECP
look here at this post
Edited by DEL80Y
