VCDS Tweaks for O3FL VRS
9 minutes ago, Janno1 said:
Will OBDeleven work on the 245 do we know?
Also has anyone used Carista?
  • Replies 60
  • Views 13.9k
  • Hi Legend, Can confirm that the coding will work on the FL03 for HBA, TCR(speed limits), Convieneance turn, Lap timer, Comfort seat(electric) on engine off and LED’s on fan speed in Auto.  Unable
  • Well guys sorry for the late reply but at last thanks to all the help from this post I gave eventually coded the twin rest fog lights and got the refill Turk quantity working. The later after a reset
  • And when you come to sell it you'll get most of your money back.    Genuine VCDS cables always hold their money well.
12 minutes ago, wg100 said:
I can confirm that the latest Beta shows the longcoding now. I've been able to perform the long coding adapatations that previously weren't possible. I too had the issue of binary only when I first got my car in Sept.
So does the latest stable software (17.8.1)
That's good to know, back in August when I got mine nobody knew Jack
Yeah, I had to figure out the HBA coding by trial and error and judicious use of Google Translate!
Guys the coding care of Andyvee
Controller 17
Coding 07
Byte 10
Bit 4
I already have a tick box for mine but the description isn't associated with the refuel quantity so I have no need to alter the binary. Unfortunately I’m at work at the moment and don’t have the VCDS cable with me so can’t give the exact description. Think it must have moved but will post a screen shot so you guys can see and advise as soon as I can.
Out of curiosity when you altered the binary to reveal bit 4 what was the description associated with it. If I had this I could hopefully run a search for it.
So far a search for ‘Fuel’ or ‘ Refill’ reveals nothing.
Incidentally does anyone have the security code for controller 17??
If you need to alter the binary there will be no description or tick box.
It will show the description on the latest software (don’t remember the exact wording but it’s obvious it’s for the refuel quantity)
25327... but it won’t work for everything (like altering the dash lights)
@Gizmo  thanks for the code and help.
Im using the latest Beta of VCDS so should be able to locate it. Probably best for me to post the screen shot of coding on my controller 17 so you can see what I mean. Just a bit frustrating I cant get to it now. :sadsmile:
Incidently I did try ticking the box for bit 4 but this didn’t activate the refuel level on the Maxidot. Didn’t seem to do anything tbh. Not even any error codes so reversed it.
There have been changes to the coding on the FL O3, so things may not be in the same place. You really need to check the descriptions of each bit that is being changed.
This is what it should look like:
For whatever reason, it didn't want to screenshot the tick boxes...
Edited by wg100
@wg100  This is what mine is like exactly. Couldn’t remember straight off but seeing your screenshot confirms it. As all can now see bit 4 is populated but not with anything related to Refuel quantity.
I have looked through all the Bytes here but nothing jumps out that could be the required bit to activate.
Guess it’s been removed now but will check once more as soon as I can however it is mentioned in the user manual so theoretically it’s in here somewhere.
Thanks wg100 for the screen shot. ;)
I don't know... Volume to be replenished sound pretty much like another way of saying Refuel Quantity to me! Remember, that phrase has been translated from German.
Doh!!
 Reading again I suppose activating bit 4 should show up the quantity in the maxidot but it didn’t when I first tried. Wonder if I have to do any resets?
Will try activating bit 4 again and a reset to see what happens.
Will post the out come.
:blush::blush:
Doh!!
:blush::blush:
Do a soft reset when you "Do it".
A shot in the dark here but would you not have to tick Bit 0 as well? Especially if none of the items in the list are currently activated.
Shouldn’t be necessary (or possible?) for longcoding,
if it was under adaptations then yes 100% a soft reset should be done though.
@RoboOp did you go back into back into byte 10 to see if bit 4 was still ticked?
Well guys sorry for the late reply but at last thanks to all the help from this post I gave eventually coded the twin rest fog lights and got the refill Turk quantity working. The later after a reset which I don’t quite understand but there you go.
Big thanks to @YMe for the rear fog help. Was missing
Lasttyp 26 - from 'not active' to '32 - allgemeine LED bis 12W '
from my coding. Working a treat now...
 @Gizmo ,  @wg100 and @SC03OTTmuch appreciate the guidance and code for controller 17 so big thanks to you guys as well. :biggrin::D
Have you got this update yet @BLACK SHEEP
Yes, but it's not very transparent in terms of what changes it makes. You select the change you want to make and hope it does the job! I've gone for VCDS now. You're welcome to my Carista dongle if you want!
Thankyou for the offer. I will keep that in mind and drop you a PM. I may go down the same route as you and go for VCDS.
As others have said before. Your spend X thousands of pounds on a nice new car, to then use a £30 dongle to change the software which runs it with no real idea as to exactly what changes are being made...
A 3-VIN VCDS cable runs to £225 which is less than the HBA option costs for factory install...
Hi Mate,
I have been in the North East for the past couple of weeks either digging my car out of the snow, or trying to secure a new job, so haven’t been on here for a while, or downloaded the latest Beta version - I’ll download it tomorrow.
Will send a PM in a minute.
@Gizmo do you think that'd be the issue for rear fogs fit us,  setting voltage to 12v as mentioned above.
Quite possibly yes, but yours are not LED fogs.
Aki78 was the genius here for the rear light coding.
My 245 already has mirror drop, speedo read out and turn signal options? Pretty sure it has both rear fogs as well.
