Engine required
Anybodys advice i need an engine for my 2005 fabia vrs can a mk4 golf 130pd engine fit into the fabia or the likes of an ibiza fr ?????
Yes, all PD130 core engines are basically the same once you swap all the ancillaries and manifolding etc. for your particular installation.
thanks very much that is good to know
also out of curiosity what would i have to do to achieve around 200bhp i have a standard  re map would i have to get bigger turbo injectors etc
Just the turbo and another remap, but your standard clutch and flywheel might struggle and a FMIC is recommended.
would i need a 150pd turbo i have been told the 130pd turbo is better but would it struggle with 200bhp
You already have a PD130 if you have a VRS, you need a PD150 turbo to make 200 BHP.
