Fabia Mk3 bulb specs volt and wattage?
i want to change my original Fabia bulbs to Osram nightbreaker laser and is 12V and 55W.
i heard that i need to fit it to the original bulbs so the car pc wont burn (also for Leds, thats why i put Halogen).
anyone know if the original bulbs is 12V 55W?
Thanks!
There are two types of headlamp unit fitted to the Mk3 (2015>) Fabias here in the UK; S and SE have the normal H4 bulbs whereas the higher spec models have the optional projector headlamps. Access to the bulbs is quite restricted, even with the wheel arch access panel removed, removing the battery also helps access the bulbs, and then the fun really starts - trying to remove the connecting cable and then the clips that hold the bulb in. I have an SE with the standard headlamps and I simply can't get my hands in to remove and replace the bulbs. From other posts on here the projector bulbs are a little easier. Search the Fabia Mk3 forum for Headlamps. Good Luck!
so the volt and wattage are also different between the two types?
RIght the Skoda handbook is really helpful about how to replace the bulb, but doesn't say anything about voltage and wattage. But I bought Phillips Extreme Vision +130% H4 bulbs that are 12v 60w/55 w main/dip for the Fabia. In my VW I have Osram H15 12v 55w/15w and Phillips H7 12v 55w bulbs.
See this thread, I'm sure someone actually posted a list of the actual bulb specs, but I've not found it. Suggest you also search Headlight or Bulbs......
Edited by thamestrader
as long as you buy the correct bulb type (i.e H7,H4 etc) then you will be fine all are standard 12v and 55/60w.
12 hours ago, wiganken1 said:
Here is a list of what I believe to be the list of light bulbs for the Mark 3 Fabia.
Fabia Mk 3 Light bulb list.pdf
I don't think that list is good.
P21/4w is a regular bulb... It's doesn't say anything about the bulb spec.
I know I have to put H7 for dipped beam.
Anyone know what H I need for fog light?
Halogen headlights:
Low beam / High beam - H4
Indicator - PY21W
DRL - P21W
Sidelight/Parking light - W5W
Projector+LED:
Low beam (projector) - H7
High beam - H7
DRL - LED
Indicator - WY21W
Front foglight - H8
Side indicator - WY5W
Rear lights:
Parking light + Foglight (lower) - P21/4W
Parking light + Stoplight (upper) - P21/4W
Parking light - W3W (2 per side)
Indicator - PY21W
Reversing light - P21W
3rd Brake light - LED
License plate light - W5W
i believe this is the list you seek, done by a forum member in 2015. So I take no credit.
7 hours ago, Pumatron said:
Halogen headlights:
Indicator - PY21W
DRL - P21W
Projector+LED:
High beam - H7
DRL - LED
Indicator - WY21W
Front foglight - H8
Rear lights:
Indicator - PY21W
Thanks! I thinks thats correct.
Someone know "powerbulb" site that suggest you bulbs that fit to your own car?
Yes www.powerbulbs.com, that's where I purchased my bulbs, they were very helpful and answered email questions promptly. I simply asked which bulbs they would recommend as  an upgrade from standard.
