Glowplugs - smoke on startup
Ive been seeing a large cloud of smoke on cold starts recently, it lasted around 20 seconds when really cold and the engine was very rough when idling for first few seconds.
This morning i thought i'd try running the glowplugs 4 times consecutively and it started with hardly any smoke and ran smoothly. I replaced all the plugs last year with NGK and they are obviously doing something but only when cycled on and off a few times.
What would be the most likely cause of this?
a look at the battery voltage may be a useful start
Battery is 12.6 volts, was new a few months ago
What's it cranking and running at? 12.4 seems a little low. Also what kind of journeys are you doing?
Edited by TripleMcB
Its running at 14.4v, and not running its 12.6 however i've had the radio on all afternoon whilst cleaning it so would be lower than normal- I never said anything about 12.4.
Cant get a cranking voltage it starts up too fast!
It gets a good run a few times a week
Edited by JWvrs25
Any excessive oil use?
What colour is the smoke?
Doesn't seem to use any oil, filled up around 200ml in 8000 miles which was mostly down to the oil leak i had
Smoke is a grey colour, will see if i can get a video of it
@JWvrs25 - This sounds very much like you have one or more bad glowplugs. It will start first time every time and run for years like this.
@KenONeill Will have to test them again then, thought NGK would be decent plugs but maybe I've got a dodgy one
Just went and tested them and I've got between 1.0 and 1.6 ohms on all of them which i think is within tolerance.
Did video the smoke but its 10 degrees this morning so wasn't that bad at all but you can see the general colour of it
Hmmm, mine starts identically to that first thing in the morning.      Is it not just soot having settled in the exhaust, seems pretty typical of a diesel?
@Clarke2744 It's when its 2 or 3 degrees and i start it, smoke pretty much fills the driveway sometimes and keeps chucking it out for about 30 seconds.
If i cycle the glowplugs its reduced to a small amount
Ahh! Sorry I’ve just read your initial post! ;)
@JWvrs25 Well, that looks fairly typical of a direct injection diesel with its quick glowplug light. The plugs on mine are pretty FUBAR and I don't get more than that unless the temperature is below 0C. Have you tried waiting until all the BITE lights have cycled before starting?
Yes, i normally wait until all lights are out until starting
it would be interesting to see what temp vag-com thinks it is.
it would indeed, will have a look and see
