Oil problem
Hi,I have a Skoda Fabia 1.4 16v mpi year 2000 model elegance
Skoda has 270.103 km(167.835mile) my car consume oil,  1L/900 km but that's not my problem,my problem is while car is working in traffic jam red oil light came on and make a beep three times and goes off,i've cheked level of oil and it's OK...
Where is problem?
  • Sponsor
Unplug the 1-wire connector from the oil pressure switch and see if the switch is leaking oil.
i did that but no there is no leaking oil
  • Sponsor
When was the last oil change?
Sounds like low oil pressure when the oil is thin with the engine hot in traffic.
i change oil and other filter in every 8000 km
yep i think that' true
Could possibly be the oil pump on the way out.
  • Sponsor
I think it is probably worth fitting a replacement pressure switch just because they are quite cheap.
Has there been any recent change in fuel consumption or engine smoothness?
well in city drive the fuel consumption it's littel higher but out of city it's normal 5.5l/100km.Engine it's working perfect
Definitely worth trying before anything else.
thanks men...i'll hope it will fix
I had the same problem and changed the sensor, and then the problem was gone. Else good pressure on these engines I think.
Edited by Torbo
@VilsonG - I'd agree with all the other people who think the problem is most likely to be the oil pressure switch.
