Fault code help please
Hi sorry for constant questions can anyone help me with this fault code
Car: Skoda Octavia
Year: 2015
Body type: Estate
Engine: CLHA 77 kW (105 HP) 1.6 l
Mileage: 48107 KM
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937086S
Software version: 0106
Hardware number: 5Q0937086S
Hardware version: 028
Serial number: 86583007140014
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 013005
Long coding: 0F001842424702DB07A04082B10407280008000000000000000000000000
Subsystems:
System description: WWS371 140703
Software version: 0570
Hardware version: 041
Serial number: 140708024911
Long coding: 0E5DDD
System description: RLHS
Software version: 0059
Hardware version: 037
Serial number: S2Y15M11D23H17M02S07
Long coding: 028877
System description: Sensor, DWA
Software version: 0315
Hardware version: 005
Serial number: 000000000ZY141272BRN
System description: Sirene, DWA
Software version: 0311
Hardware version: 004
Serial number: 00000000000030338260
Trouble codes:
B126A29 - Light switch Implausible signal
static
What symptoms are you seeing from the fault code?
Edited by SWBoy
Am I right in thinking you retrofitted auto lights recently? If so it might be worth mentioning what was changed/coded as part of the retrofit.
Yes retrofitted auto lights with a new rlhs and a used auto light switch. When the switch was in the auto position before I ran the extra cable from the switch to the BCM the lights would be on all the time but no fault code. Now I have run the cable I am getting this fault code come up.
Just the Amber warning symbol on the dash a lighting system fault message on the maxidot and a warning on the infotainment unit with the headlights coloured orange but the lights seem to be working OK
I'd expect you'd need to update the coding on the BCM/Cent Elec module to tell it that it now has the auto lights switch and RLH sensor. Have a read of this thread for the Golf:
http://www.golfmk7.com/forums/showthread.php?t=10534
I have followed one very similar and I think I have coded it correctly need to go out and double check it someone said it was a faulty switch on one of the skoda groups on Facebook
Edited by Bigtow
Just been out and double checked the wiring and the coding and followed this guide and hey presto they are working with no fault code thank you all for the help and advice you are fantastic. Now just got to work out how the ch/LH function works as I have the options to change the time settings on my infotainment unit now
Here is the guide I used to get it working "
I have no errors showing and both rain/light sensors are working as well as coming/leaving home functions.
I have a 2013 FR and the parts numbers I used are 5Q0955547B for the sensor and 5G0941431AF-WZU for the switch which has the correct colour lighting, only difference being the small amount of silver trim is brushed aluminium rather than the chrome on my original switch.
To start with swap the sensor and switch as described in the other instructions, fire up OBD11 and go into control unit 09 Central electrics.
https://farm5.staticflickr.com/4337/35967818834_aef25dc78d.jpg (https://flic.kr/p/WNmtru)
Select Long Coding
https://farm5.staticflickr.com/4400/36663263431_23ae6c6021.jpg (https://flic.kr/p/XRNNTz)
Select this symbol to move from the textual long coding into the standed format.
https://farm5.staticflickr.com/4340/36663263141_6d16335439.jpg (https://flic.kr/p/XRNNNz)
The screen will now look like this, notice the byte 00 in the top left hand corner. Press the arrow in bottom right to move to byte 06.
https://farm5.staticflickr.com/4387/36663262941_f70d39b48c.jpg (https://flic.kr/p/XRNNK8)
When there select the tick box indicated (bit 01) and hold the green tick to save the settings.
https://farm5.staticflickr.com/4338/35967816694_0e01089af2.jpg (https://flic.kr/p/WNmsNA)
Arrow once to the right (byte 07) and make sure the screen looks the same as mine with bit 0,1,3,4,5,6,7, all selected, hold the green tick to save the settings.
https://farm5.staticflickr.com/4392/35967815924_1bf82aa1bb.jpg (https://flic.kr/p/WNmszj)
Now go back to the control units menu and select "Adaptation"
https://farm5.staticflickr.com/4374/36663262401_1b7a124cdd.jpg (https://flic.kr/p/XRNNzP)
Select Assistance light functions.
https://farm5.staticflickr.com/4404/36663262131_4628aa8a4e.jpg (https://flic.kr/p/XRNNva)
Make your adaptations the same as mine. I noticed at this point that I had less available adaptations than in Deathjam's guide but I just made the ones I did have the same so don't panic if you have more adaptations just fill them in as in his guide further up the thread, hold the green tick to save the settings.
https://farm5.staticflickr.com/4348/36663262081_18f3ef6755.jpg (https://flic.kr/p/XRNNui)
Back to Adaptations menu and select "Comfort illumination".
https://farm5.staticflickr.com/4436/35967814334_ea3f6e9a69.jpg (https://flic.kr/p/WNms6U)
And again make sure you adaptations match mine, hold the green tick to save the settings.
The last thing that threw me a bit was the 2 settings below, you will notice they have different values to mine. It wasn't possible for me to enter those values in OBD11 so after a bit of searching the internet I found that the values I have used (2 and 116) were the correct ones.
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 18 lx
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx
https://farm5.staticflickr.com/4350/36663261681_891f2df5a3.jpg (https://flic.kr/p/XRNNnp)
Disconnect from the car and turn the ignition off, you may have to go into car setup to enable the coming/leaving home "
