Torque Settings & Towbar
Hi guys,
Recently bought a 2013 Octavia combi TDi Cr Elegance.
With previous cars I've always bought the Haynes manual... but as far as I can make out there's no Haynes manual for this model Octavia?
Can anyone tell me where I could get the likes of torque settings (and other bits of information that tends to come from a Haynes manual) for this model?
Also, I found the detachable towbar in the sparewheel compartment... but I've no key for it! Does anyone know if these are easily replaceable or if I can use it without the key?
Thanks for any help or advice you can give me
There should be a number on the lock barrel where you put the key in. That’s the code for a replacement key. Westfalia hooks won’t let you take the key out unless it’s fixed in position on the car first.
Edited by BigEjit
Thanks for your help guys.
I'll have a look at both of those sites for workshop manuals.
Regarding the towbar - I'm not sure if it's a Westfalia one... it has a VW part number on it. I'm assuming it came with the car from the factory.
Key may be the same pattern as Thule roof rack ones. Cheap cut-to-code on eBay.
