09 fabia electric windows
My 09 skoda fabias electric windows are not working. I have replaced the two fuses and still no joy. I have replaced the window regulator not long ago as it broke but both windows were working after that. I have also checked all the plugs and wires and none of them are broke. There is power going to both switches.
Any info or help much appreciated
You may need to replace the drivers door window motor, it also contain the control unit, first check the wires in the door bellows for continuity, they have been known to break inside the insulation.
I have checked the wires with no joy. The lights on the switches are lighting up.
33 minutes ago, sepulchrave said:
You may need to replace the drivers door window motor, it also contains the control unit.
