Specification Checker
Does anyone know if Skoda have a specification checker site, similar to the Ford Etis software, where the built spec can be checked using the VIN?
I got excited when it let me register for free, didn't get far though :D
  • Sponsor
For a handful of Euros you can download your full car data via the Vehicle-specific Info tab, then under the Individual Vehicle Info tab you can download pretty much any repair/maintenance info you like about any model you like, plus as many SSPs as you might find interesting.  It's a real bargain TBH.
Browse around and work out what you want to download before you start your hour, then get downloading once you've paid.
Thanks for all the replies chaps. 1 hour access should do fine. I've bought a new Kodiak Edition and really want to know if it has been specced with an electric supplemental heater to heat up the cabin on very cold mornings. I had one in a diesel Mondeo and it was a welcome addition.
Just to let you know, I got the full spec sheet from Skoda and my Kodiaq Edition Diesel 190 Bhp does indeed have an electric supplemental heater fitted as standard.
Edited by colmar51
word missing
Was this standard, or was it a cost option?
I wasn't even aware it was available as an option in the UK... but then colmar51 doesn't have a location specified so he (or she) could be anywhere.
Just to clarify - I'm a he, I live in Glasgow and the weather up here is proper baltic at present, the supplemental heater wasn't an option. Apparently it's a standard feature. In Nordic countries I think the Webasto style heater (fuel driven) is far more common. In my experience the operation of the electric heater is quite subtle. Initially I didn't believe my Mondeo example was working until I stuck a temperature probe into one of the dashboard air vents and watched the temperature climb.
I only collected the Kodiaq two days ago so it's a bit previous to say how efficient this heater is. I'll let you know as soon as.
Where do I enter the VIN number???
Once you've registered you'll see the screen pictured above. You then select the flat rate you want (I took 1 hour only then printed the complete spec). Once you've done that another screen appears with a box where you enter the VIN
Thank you.    :biggrin:
Doesn't work.
Tried 3 different credit cards, two of them with NOTHING on them, so its their system that's at fault.   :angry:
No, NO LUCK WHATSOEVER
Edited by Macdemon
3 minutes ago, Macdemon said:
Doesn't work.
I don't know if it'll make any difference but I used a Visa debit card and I had no problem.
Mine were 'MasterCard and Visa credit cards, I will try a MasterCard debit card and report back in a few mins.........................
As per above
