Enabling Traffic Sign Assist/ Fatigue Detection
@linni
Aahh,, Well I always use this bit button, so I come close to how VCDS works. As Obdeleven without this activated is kind of all over the place.
  • Replies 87
  • Views 27.5k
  • Hello. I found the following link in this thread and I tested it today. It worked perfectly on Octavia 3 MY2015. I see above that it was widely discussed if the option is useful or not, but I still li
  • If you have lane assist you can have traffic sign recognition. Done it on 3 Superbs and 1 Octy so Kodiak should be very much the same I presume.
  • Lane Assist on the O3 wasn't particularly nice when set to 'adaptive' mode. As you say, it seemed to bomb out lots even with both hands firmly on the wheel.   However, Lane Assist on the Kod
Thanks, good to know.
You have a lot of things activated, that I do not ;o)
Two specific settings caught my eye
FPA_Funktion_ACC: active
PFA_Funktion_ESP: not active
I know my car has ACC, but it also has ESP. Weird why this is not active, if this is indeed ESP settings. It could be something totally different though.
I believe RS has ESP Sport mode, which regular Kodiaqs do not have? Somehow connected to this case?
P.S. But don`t waste your brain cells on this. There are ls of weird things in codings, which answers know only some VAG code masers.
Edited by linni
@linni I know ;o) - and I'm not touching any of that.....
Regarding car pricing. I just saw something even more ridiculous (maybe). Does the RS version in Estonia come with Area View. Cause I think your RS versions is even more beef'ed up than our version.
Ex. our RS version comes with Amundsen, not Columbus. And even on the RS version, these are still extra options:
Electric Tailgate
Electric passenger seat
Heated backseats
Glas roof
Parking assistent
Rear curtains
Lane assist
Sleep package
Side airbags in third seat row.
No area view, no Columbus, no ACC (just basic cruise control), no sunroof in standard. Cannot remeber exact specs.
I just pimped it up. Starting price 44 000 euros here at this time, I added extras for 11 000 euros, final price 55 000.
I know the car tax god has been generous in Estonia :)
Edited by linni
OK. Then our standard RS version is not completely of spec wise, just 47.000€ more expensive...  crazy....
https://ww2.skoda.dk/priser/kodiaq/
the price is in DKK
Edited by snowatom
Image upload
Yeah, Denmark and Norway are probably the only countries in the world, where used car costs more than new one in other counries.
  • 6 years later...
@linni
Hi, I'm pretty new to this.
I'm using Car Scanner to enable traffic sign recognition on my Kodiaq 2021.
After enabling, I can see the feature in the Multimedia and screen, but it gives an error. Can you help me solve it?
I also need help working on adding adaptive lane assist in the menu to select between early and late, and disabling the "hold steering wheel" notification.
@hamid_v Not familiar with Car Scanner. I did not enable these features on my car as I ordered them as options. You need specific camera, not all of them can be coded first. And not sure that 2021 car can be coded at all. Factory cut the access to OBD around that time.
Thanks for your kind reply.
Car Scanner is like a basic simple OBDeleven.
It does have some apps, but to do more, I have to use long coding which uses binary and hex.
I believe the camera on my car is called 3QO or something similar.
Regarding the ability to code, I can code as I enabled adaptive line assisst. But on the menu, it is a on/off toggle and I can't choose early/late.
If you can kindly share the binary changes/long coding for the trafic sign, I can manually find input those values using Car Scanner.
Thanks for your help.
Ok, will check tomorrow.
@hamid_v
Sorry, takes a bit longer, too much work.
