Dynamic LED DRL turn signal
Hi, wondering if it is possible to modify the currentl front  led DRL turn signals on Karoq via VCDS/OBDeleven to make them dynamic like audi turn signals??.
https://www.youtube.com/watch?v=SNWOHTxpLT8
Unfortunetly only front lights LED as rear still regular bulb although plan to change that to led type bulb.
Not according to the the list Arkaig found.
These are the functions you should be able to carry out...
Adaptation of the welcome logo in the on-board computer
Representation of the selected driving profile in MFA (multifunction display)
Adjustment of the tailgate to close with FFB (radio remote control)
Deactivation of the entry AM in the radio menu
Activation of the summer time automatic as menu entry
Add off-road ad
Show top speed in navigation (with built-in VZE)
Activate Green Drive Menu
New display design (Kodiaq)
Activation of fog lamps (NSW) as cornering light
Activation of fog lights (NSW) as cornering light on RS models
Adaptation of the speed thresholds for activating the cornering light via fog lights
Adaptation of the dynamic start-up assistant
Passenger mirror lowering when reversing
Subsequent activation of the Hill Hold Assistant
Adaptation of hill start assist
Activate US parking light for the front turn signals
US parking light only at Coming Home / Leaving Home
Activate display of the refueling quantity in the on-board computer
Adjustment of the intensity of the brake disc drying
Automatic activation of the CH / LH function
Activate CH / LH only with TFL (daytime running light)
Activate CH / LH via fog lights
Increase the coming home glow time
Increase the Leaving Home Luminous Duration
Coming home power-on event
Activation of horn acknowledgment with DWA + when locking and unlocking the vehicle
Activate the visual display of the parking aid via the audio or navigation system
Deactivation Activation tone of the parking aid
Adjustment of the request for the audio reduction
Adaptation of the shutdown speed of the parking aid
Parking assistance safety distance
activate automatic activation of the parking aid
Adjustment of microphone sensitivity
Activation of the driving school mode in the CAR menu
Activate release run of the windows when opening the door
Enable high beam assistant
Adjust Speed Threshold for High Beam Assistant Activation
Prevent Reset / Reset High-Beam Assistant
Enable freeway light at high speed
Disable Gurtwarner
Adjustment of the heating time of the rear window heating
Adaptation of the light switch-on threshold of the headlights
Deactivation of the tear-wiping function of the front / rear wiper
Display of the comfort wiping function of the rear window wiper in the CAR menu
Automatic locking, locking, locking the vehicle
Display of the fan speed in AUTO mode of the air conditioner
Adjust the comfort indicator cycle
Subsequent unlocking of the Lane Assist - Lane Keeping Assist
Adjustment of Lane Departure Assist of Intensity Steering Assist, Intensity Steering Wheel Vibration, Deactivation Threshold Driver Inactivity
Activation of the lap timer
Activation of the LED license plate light
Display of the oil temperature display in the FIS via lap timer
Display of the oil temperature display in the FIS via consumption display
Sunroof (SAD) - Panoramic glass roof Activate comfort opening
Activate the rain closing function
Activation of reversing camera (RFK)
Adaptation of the speed thresholds to activate the city light
Adjusting the luminosity of the reversing lights
Storage of the last set seat heating level
Adjustment of the temperature setting of the respective seat heating stages
Adjustment of seat heating return thresholds
Disabling or adjusting the volume of the structure-borne sound actuator
Adaptation of the radio mode of the Spiegelanklappung
Extension of the activation interval of the headlamp cleaning system for the front washing system
Delayed response of the headlamp cleaning system for the front washing system
Activation of the parking light of the taillights for the (LED) daytime running light
Activation of the fog lamps (NSW) in addition to the daytime running lights
Deactivation of the daytime running light with the handbrake pulled
Activation of the daytime running light function only in switch position Auto on
Possibility to deactivate the daytime running light in the CAR menu
3. Brake light as receipt ZV
LED daytime running lights do not dim when flashing
LED daytime running light dimming when flashing
Fog lights as flashing lights when no low beam is active
Dimming the hazard switch
Activate AFS (Adaptive Headlamp) (only possible with Xenon with dynamic cornering light)
Activation of the ambient lighting even when the exterior mirrors are folded
Adjust consumption display (FIS)
Activation of the traffic sign display
Activate pointer test / pointer deflection / staging
Deactivation of the message / continuous tone at ignition on
Deactivate Start Stop
TV / DVD / Video Picture activation while driving
Unlock "alarm system" (without sensors)
Lock the car even though the engine is running (only with Kessy)
Pity - ok thanks for list
My understanding is the function is hardware driven, not software.
