Fabia Dashboard Storage Draw
Part No: 6Y0 858 332 47H @
Yep
Radio out, reach back behind your existing starage tray and give it a sharp tug, it'll come out in your hand :D
The storage draw will just slide and lock in the same place.
Don't forget to buy the little mat inside as well.
Cheers Stu. All I'll need then is a Radio removal tool!!
I find it easier to get the radio out if you remove a few of the spare blank buttons above and gently give it a little lever out.
Not the end ones though - they are fixed.
"Spherical male appendages" Graham:finger: :rofl:
The W.O. says they ARE Fripperies ! :confused:
Robbo, I removed my radio using a a hacksaw blade snapped in two, just the job. Also someone mentioned a cut up credit card will also work.
My next job is to wrap a bit of electrical tape around said snapped hacksaw blade bits to stop any accidental scratches.
RBW
Robbo' date=' I removed my radio using a a hacksaw blade snapped in two, just the job. Also someone mentioned a cut up credit card will also work.
RBW[/quote']
Cheers Geoffrey!!:thumbup:
