Octavia 1.9 ASV 110 BHP Turbo Issues :(
HI All
My car is the ASV 110BHP TDI MK1 Octavia, it had turbo issues so I went out and purchased a recon Delphi turbo… thinking all will be well.
Fitted it with a new oil feed cleaned inlet blanked egr etc.
I have been driving the car about a week, and it is over boosting :( It only over boosts at lower rpm when climbing a hill, so I did not detect it straight away but suspect it has done this since turbo has been fitted.
I have swapped the N75 valve and this had not made a difference. I am suspecting it is the actuator arm which may need adjusting, but I thought Delphi would have done this. I have also no experience in doing this but willing to learn…
Anyone got any tips please? On anything else I can check ? I have had a enough of this car..
O yea I have full vagcom so can carry out any checks with that.
Thanks,
Jon
Edited by cyber_killer
Update
The turbo is now the same as previous one... slight touch of pedal and major over boost. I have no idea what is causing this:(
Any fault codes showing up ?
Is there a lot of gunk inside the inlet manifold in the region of the EGR ?
Thanks,
Yea the fault code is over boost P code...
The inlet and EGR have just been cleaned out and the EGR is blanked.
On 5/5/2018 at 23:28, cyber_killer said:
Thanks,
Suspect areas are holes in the intercooler, leaks in boost pipes (hard to pinpoint them often unless there is a big *** crack/split) or turbo vanes sticking......
