Noisey Blower motor
Hi all,
           I've got a loud noise coming from the blower motor, I've tried taking out the cabin/pollen filter to see if I could get anything leaves ect out but no joy. Just trying to work out how to get to the blower motor without taking the dash apart, any suggestions would be greatly appreciated.
Many thanks
Unfortunatley, the blower motor on the  Fabia 2 is a dash out job. This also means removing steering wheel, along with possibly quite a few bits and bobs to get to the necessary removal screws and fitments.
Can you get to the outer side of the motor from under the window scuttle to check for leaves ?
Its inside the cabin so leaves would most likely be found under the dash, through the pollen filter aperture.
