Help with VCDS needed
Good evening, I am needing help, I dont have a fabia but I am sure you guys could help me out
I have been having this problem with my car The EPC traction control light and CEL come on
Car seems to go into limp mode and sounds as if it is running on 3 cylinders but you turn it on and off and all is fine for a while but then after a while the light come back and limp mode returns.
Ive cleaned my throttle body and that cleared the problem for about 2 week, ive replaced all my ignition coils and had new spark plugs put in.
Is there any measuring blocks I can use to help me diagnose my problem.
Friday,25,May,2018,21:02:11:00006
VCDS Version: Release 18.2.0 Running on Windows 7 x86
www.Ross-Tech.com
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Control Module Part Number: 1ML 906 032 A
Component and/or Version: 1.8l R4/5VT 0001
Software Coding: 10510
Work Shop Code: WSC 64004
Additional Info: VSSZZZ1MZ4R073305 SEZ7Z0C2304994
VCID: 3F8DF5FE3D7DBABC21-5178
7 Faults Found:
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
17956 - Boost Pressure Regulation Valve (N75)
P1548 - 35-10 - Open Circuit - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-00 - Open or Short to Plus
17976 - Throttle Actuator (J338)
P1568 - 35-10 - Mechanical Failure - Intermittent
Readiness: 0000 0000
To save us playing guessing games can you tell us what engine we're looking at even if the car itself must remain a secret?
