Coding for vehicle display on MIB2
Hi, I've just put a MIB2 unit in my 2014 Octavia, all working fine apart from showing a Superb Estate on the screen instead of an Octavia Estate. Does anyone know how to change this using VCDS? I've tried looking at long-coding on 5F but it says it's not available.
Can you post a complete autoscan?
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 47 52 55 5F A5 A9
VIN: TMBKK7NE9E0192512   Mileage: 82672km-51369miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7543
   Revision: 83H22---
   Coding: 111D0012030501080000
   Shop #: WSC 73430 031 00207
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74EDD618DF9C74E433-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4304
   Revision: 05852204    Serial number: TFK01403011666
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 254BFB5C24C65D6C74-8070
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 60674000000B99
   Coding: 1C0793915429096E007C060141C52938C92A9000608294F400610070C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4B9F6DE4E2E24B1C82-801E
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 E    HW: 5E0 907 044 E
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2757F1545ECA4F7C46-8072
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
1 Fault Found:
590081 - Control Circuit for A/C Compressor
          B10A9 11 [008] - Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 254
                    Mileage: 82367 km
                    Date: 2018.06.07
                    Time: 08:35:41
                    Outside air temperature: 13.5 °C
                    Engine speed: 2300 /min
                    Compressor shut-off requirement: Compressor activation: malfunction in activation path
                    Compressor current: actual value: 0.000 A
                    Compressor current: specified value: 0.000 A
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86581403140089
   Coding: 0F001A42C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00207
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 489552E8F394A004AF-801C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140228  041 0570
   Serial number:         140305044316
   Coding: 065DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y14M03D15H10M44S35S8
   Coding: 02805D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY140230E4Y
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000028372375
   Relative Air Humidity Interior Sender:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831407402164
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 387522288374D084DF-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P4TVHT
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F070934E6DA27BC5E-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 000 203 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U00000092DB80F0N
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 000 203 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000852742F09
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 103 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516RAEFC1203000000D
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 802 802 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R16712003000000K
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 401 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556V9A26BD02000000H
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 24011404220064
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 79F3E72CF8FE098C60-802C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 961 F    HW: 5E0 920 961 F
   Component: KOMBI         233 2210
   Coding: 27A509086984A60001086A02000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 2B5F0D6442226B1CA2-807E
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001673334
   Coding: 030100040F087300EF00066A1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010_VW37.rod
   VCID: 3F874934A65AE7BC1E-806A
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000C1268070314
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 5553212803
1 Fault Found:
15360512 - Component Protection
          U1101 00 [009] - Active
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 236
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:11
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000095515337
   Coding: 001C00208001040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 428140C0D5A88A5471-8016
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000002068118
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 356B2B1C94662DECC4-8060
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000095126985
   Coding: 001C00208C01040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 41834FCCD0AE914C68-8014
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000002049060
   Coding: 050200
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 03DE02003F000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40854AC8DBA4984467-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 8S0 035 021 E    HW: 8S0 035 021 E
   Component: MU-H-LND-EU   052 1027
   Serial number: A710J0G7509432
   Coding: 03840201FF0000005111120100880A332F0101C401200100DE
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H50 0022
   Serial number: SKZ8Z9NL100ER8
   Data medium:
   Subsystem 2 - Part No SW: V03 959 801 JQ    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Serial number: --------------------
   Compact Disc Database:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2---  --- 1013
12 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] -  -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:19
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: MDUK107/ABT
15360256 - Component Protection
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:13
2571 - Navigation system
          B126C F2 [009] - Navigation database not enabled
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:14
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 82579 km
                    Date: 2018.06.14
                    Time: 08:32:24
                    Interface for external media: status-Status: Measured value not available
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:13
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:13
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 14
                    Reset counter: 22
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:19:38
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:15
                    BAP-BAP_Function_ID: 02
7171 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:15
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:15
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:15
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:15
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0052
   Serial number: 10000048433
   Coding: 0101000001030304000400000000010100
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B7F3D24B242FB9C32-806E
1 Fault Found:
2555904 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 159
                    Reset counter: 237
                    Mileage: 82282 km
                    Date: 2018.06.04
                    Time: 13:17:11
                    Control Module temperature: 48 °C
                    Outside air temperature: 15.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 11.9 V
                    Terminal 15 on: 1054.3 s
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140301201440
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 69D3B76C885EB90C90-803C
It appears as though you're using an older interface (and software) which isn't compatible with the controllers in your vehicle. A next generation (Hex-net or Hex V2) with VCDS 18.2.1 will allow you to access all the missing controllers. There are many faults there which I'd be unhappy leaving on the car so either update your existing VCDS (which may help a bit) or obtain a latest gen one.
Additionally, the MIB2 unit you have fitted is an Audi unit. Are you sure the vehicle data isn't showing an Audi Estate?
I'm using VCDS 18.2.1 with a GENDAN HEX+CAN cable, it is quite old though! Do you have a link to the best one to buy?
The MIB2 unit has Skoda code on it, I bought it from vagtec, they must just re-purpose the units as they need them, it has a skoda face on the front of it. The car display shows a Superb Estate, I've managed to change the splash screen to VRS but don't know the bits to set to show an Octavia.
There's a stuck post at the top of this section with details of what to buy and where from (here). Depending on your needs, either a 3 vin or a 10 vin Hex V2 would probably be the way forward. Best value is a 10 vin one and then an upgrade to unlimited vins as required, but if you want the cheapest option then a 3 vin would be the way. That however limits you to only using it on 3 cars, but if that's all you want then cool.
If you want wireless connectivity and other stuff then the Hex Net is worth considering for more money. Not something I personally value though as cables tend to be more reliable than wifi / bluetooth in my world.
Your current interface will probably sell for enough to fund a new generation one too.
As for the units identity. Sounds like they buy them and replace parts to suit the market (or a damaged Audi fascia will become an undamaged Skoda unit perhaps with the swap of a faceplate).
Thanks, I think i'll go for the HEX NET when it's back in stock at gendan. Does the new interface show the long coding helper for 5F then or do you think that's down to me having an Audi unit in a Skoda car, currently when I try to access long coding helper on 5F I get a message saying it's not available.
Yep, you'll be able to access long coding with a new interface.
You'll also be able to clear the Check Software Management Version error manually as VCDS can't do this. Simple to do as detailed here by aki78...
On 2/4/2017 at 16:58, aki78 said:
Guys, this is how you clear the software version error with VCDS:
5F module
Adaptations
Channel 'Confirmation of installation change'
Note your current code (different in every vehicle!)
Calculate your new code and enter it on the channel
Don't be surprised: the adaptation channel will change back to the original coding, this is normal!
Calculation (use Windows Calculator in 'Programmer' mode and select 'HEX'):
'original code' Xor C9D2 = (your new code)
Note the following:
VCDS use 'xx xx' format, but you have to use 'XXXX' format for calculation.
If your original code starts with zero just remove it before calculating.
If your new code is less than 4 characters insert zero(s) in the beginning.
Calculation example (just C9D2 is fix here!):
Original code: 1a 1a
Conversion: 1a 1a -> 1A1A
Calculation: 1A1A Xor C9D2 = D3C8
Conversion: D3C8 -> d3 c8
The above calculation method is from the Skoda update document and it works. :)
Edited by Rustynuts
Why have you installed Audi TT unit 8S0035021E unit instead of native Skoda version? I believe this could be the root cause of your problem
It's explained above, everything is working fine now.
I've just read it in another thread, sorry for confusion.
  • 1 year later...
Hello! I have made a retrofit bolero mib1 to Columbus Mib2 with sim card. I cant see 2 functions in menu: wlan and i cant copy music from external. The guy that installed the unit gives me some function that i need to activate, but it is with odis and i have only VCDS. Can someone help me with activitate these functions?And i have some erros with all speakers, open... Thank you so much
Edited by bgd1106
