Head light washer relay location.
Hi. My headlight washer has stopped working. I scanned  with vcds  discovered that the relay is faulty  but I can't find the location of  the relay. I had a look under the dash but it's not there. Does anyone know where it is? Thanks.
The relays are in the engine bay fuse board next to the battery.
There is also a fuse in the fuseboard at the end of the dash. From memory this fuse feeds power to the relay so is worth checking. The fuses tend to go when the washers get stuck out in freezing weather.
Thanks. I have looked under the dash and next to the battery but can't find that relay. I will take a look at the fuse and hope it's the fuse.
Thanks etskoda .You wore right .It was only the fuse.
