Tyre size?
Hi, decided to buy 8Jx19" 5x112 ET48 wheels, what tyre size should i buy? Will 225/35 r19 be fine?
235's are cheaper generally & the circumference difference isn't worth worrying about
whats the difference between the 225 and 235? I’m not good with these numbers, thanks!
If you swap out the manufacturers fitted tyres from the recommended specs, have a blowout, crash into an infant school and kill eight brats then you'll be charged with manslaughter.
If you're driving the exact same car with manufacturer fitted tyres, you won't even be charged.
Your choice.
  • Sponsor
235s are nominally 10mm wider than 225s.
Your choice.
Who you ? The police or something
thanks mate
I run 235-35 on my 18’s and they are spot on
If you are fitting non standard tyre sizes then make sure you inform your insurance. It's a modification.
Au contraire (you might need to pump that into a French-English translation service).
Just a piquant (you might also need to pump that into a French-English translation service) observation on the UK political landscape in 2018.
Do "au contraire" and "piquant" at the same time.......you'll save yourself a few minutes.
Also the 235 will be 7mm bigger in diameter.
Yeah, the Speedo read a whole mph low on the motorway
Jokers the lotta ya, in the real world it's a nothing
.. I would check the local regulations about what's allowed and what not and what your insurance company or roadworthiness test would have to say before going much further.
 - Bret
