MFSW and coding help please
Evening,
Added a MFSW to my non-maxidot octavia 2011 mk2 fl vrs this morning,
Hardware installation went ok. Airbag out, steering wheel off and changed the steering module. Updated the airbag loom to the steering controller one also (3T0971584)
Changed the steering controller to 5K0953569AL.
Refit went well and then hit a snag with the coding. To be honest off the bat the horn worked, the cruise control worked, the left and right track button and phone button also. The volume rocker was a no go and the wiper stalk was not able to control the non-maxidot.
Initial scan found quite a few faults :blush: Quite a few of them from a flat battery i must add.
1st scan on vcds -
Tuesday,19,June,2018,14:54:47:16696
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
          77
VIN: TMBEF61Z2C2021817   Mileage: 94200km-58533miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: AAH18---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 73430 790 00083
   VCID: 79F39CD530986AE9291-802C
2 Faults Found:
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 9.017 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 9.779 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 163B601C092400FB681306E590200081340800
   VCID: 79F39CD5F0986AE9291-802C
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 93706 km
                    Time Indication: 0
                    Date: 2012.10.13
                    Time: 15:43:59
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50176
                    Count: 0
                    Count: 64512
                    Count: 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 7CFD85C1F7AA5FC1327-8029
No fault code found.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 40000AB8A05BB1C040100080310011E4477000AE736D8960808400040040
   VCID: 3F8732CDAE3C84D9575-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 09061  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 200611 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
15 Faults Found:
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00924 - Relay for Headlamp Cleaning System (J39)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
01259 - Fuel Pump Relay (J17)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
03266 - Control Circuit for Signal Horn
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.95 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
03396 - Supply voltage terminal 30 for central locking
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:36
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.95 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00153 - Windshield Wiper Motor;  Driver Side (V216)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:39
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00059 - Terminal 30 for Interior Lighting
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 13:56:45
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.90 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00061 - Footwell Lights
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:22:45
             Freeze Frame:
                        Term 15 Off
                    Voltage: 10.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:22:46
             Freeze Frame:
                        Term 15 On
                    Voltage: 8.60 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:29:31
             Freeze Frame:
                        Term 15 Off
                    Voltage: 10.70 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:29:49
             Freeze Frame:
                        Term 15 On
                    Voltage: 8.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:29:49
             Freeze Frame:
                        Term 15 On
                    Voltage: 8.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00154 - Windshield Wiper Motor;  Passenger Side (V217)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:29:49
             Freeze Frame:
                        Term 15 On
                    Voltage: 8.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:29:60
             Freeze Frame:
                        Term 15 On
                    Voltage: 7.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28291110971389
   Coding: 108002
   Shop #: WSC 13765 790 00083
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 438F3E3DCAD4E03933D-8016
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Date: 2018.06.18
                    Time: 16:29:46
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q8 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2635H
   Coding: 0020792
   VCID: 3D7B48C5643096C9459-8068
   Subsystem 1 - Serial number: 6332MSME5F73791EW
   Subsystem 2 - Serial number: 6342MSME6022531C3
   Subsystem 3 - Serial number: 6351HSME277F1724C
   Subsystem 4 - Serial number: 6361HSME27721422
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 501 CQ    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0180
   Revision: FF010042    Serial number: 20160223200443
   Coding: 198A140000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 7BFF86DDF2A458F93BD-802E
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Serial number: 0195124
   Coding: 820000
9 Faults Found:
0516 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 115
                    Mileage: 101118 km
                    Date: 2018.01.30
                    Time: 11:30:13
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 63421 km
                    Date: 2012.10.30
                    Time: 10:11:27
136194 - Supply voltage
          U1011 00 [008] - Voltage too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 63421 km
                    Date: 2012.10.30
                    Time: 10:11:27
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
227355 - Windshield Wiper/Washer Switch
          B1149 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 53
335876 - Powertrain Databus
          U0002 00 [009] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 115
                    Mileage: 94191 km
                    Date: 2018.06.19
                    Time: 00:01:17
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 54
                    Mileage: 101118 km
                    Date: 2018.01.30
                    Time: 11:25:08
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 13
                    Mileage: 101118 km
                    Date: 2018.01.30
                    Time: 11:30:12
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 903 R    HW: 1Z0 920 903 R
   Component: KOMBI         H04 0607
   Serial number: 00000000000000
   Coding: 710E01
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 448D3D21CFDAE7010A7-8011
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 100611F2002972
   Coding: 351303
   VCID: 356B50E59C004E898D9-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 91060 km
                    Time Indication: 0
                    Date: 2012.07.12
                    Time: 13:37:25
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AD1B3998D3ED171D0B-803F
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660222190
   Coding: 010000
   VCID: 29538C9540B81A69191-807C
1 Fault Found:
03138 - Input AUX IN
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 115
                    Mileage: 94191 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 01:22:40
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 G    HW: 3T0 035 680
   Component: RNS-MID       H11 5269
   Revision: AB001001    Serial number: SKZ6Z7J6041035
   Coding: 04000400000100820000
   Shop #: WSC 35110 377 00999
   VCID: 346D6DE1977A5781BA7-8061
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:22:31
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:20:33
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0000756
   VCID: 489529113BF2C361E6F-801D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 346D6DE1577A5781BA7-8061
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 47972A2D36ECCC19EF5-8012
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1507610
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000023
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:22:31
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 94171 km
                    Time Indication: 0
                    Date: 2012.11.08
                    Time: 16:20:33
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012563
   VCID: 32616BF9AD6E59B1A8B-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F6EFD527450B9A3D-8066
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664306085
   Coding: 0A01000000010101
   Shop #: WSC 00028 028 00020
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 39735CD5B818AAE9691-806C
1 Fault Found:
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 91060 km
                    Date: 2018.02.19
                    Time: 13:37:25
End-------------------------(Elapsed Time: 03:08)--------------------------
Cleared some of the faults and the 2nd scan showed the following -
Tuesday,19,June,2018,15:38:33:16696
          77
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Voltage: 9.017 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Voltage: 9.779 V
   Revision: 00H31001
   Revision: 00001007
   Coding: 0000000002
   Revision: 00110 AC
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 108002
   Coding: 0020792
   Coding: 598A140000
   Coding: 820000
3 Faults Found:
0516 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Date: 2018.06.19
                    Time: 15:13:45
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Date: 2018.06.19
                    Time: 15:13:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Date: 2018.06.19
                    Time: 15:13:45
   Coding: 710E01
   Coding: 351303
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 94200 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 15:13:48
   Coding: 000000
   Coding: 010000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 15:37:04
   Coding: 0000756
   Revision: 00H20000
   Coding: 0000756
   Coding: 1507610
   Coding: 00000023
   Coding: 00000023
   Coding: 0000144
   Coding: 0000144
   ROD: EV_UHVNA.rod
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Date: 2018.06.19
                    Time: 15:13:45
End-------------------------(Elapsed Time: 03:01)--------------------------
So a bit of reading around etc and this this seemed to have been reported before so I followed the instructions on VCDS and added the wiper back in - no problem.
Codes didnt want to clear so i followed this here -
I updated the coding to 5080140000 in a hope of getting rid of some of the fault codes. And it worked...... ish.
The steering sensor no longer needed calibrating and some other bits and bobs were cleared.
This was my third scan -
Tuesday,19,June,2018,15:57:57:16696
          77
16-Steering wheel -- Status: OK 0000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Voltage: 9.017 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0°C
                    Temperature: 30.0°C
                    Voltage: 9.779 V
   Revision: 00H31001
   Revision: 00001007
   Coding: 0000000002
   Revision: 00110 AC
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 108002
   Coding: 0020792
   Coding: 5082100000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   Coding: 820000
   Coding: 710E01
   Coding: 710E01
   Coding: 351303
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 94200 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 15:54:15
   Coding: 000000
   Coding: 010000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 15:56:20
   Coding: 0000756
   Revision: 00H20000
   Coding: 0000756
   Coding: 1507610
   Coding: 00000023
   Coding: 00000023
   Coding: 0000144
   Coding: 0000144
   ROD: EV_UHVNA.rod
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 94200 km
                    Date: 2018.06.19
                    Time: 15:54:13
End-------------------------(Elapsed Time: 02:56)--------------------------
But the problem i now have is that i have a can-gateway issue on module 19.
Didn't know if this was anything to do with anything -
I gave up poking around and thought it best to check with a guru.............
Most annoyingly the volume rocker still isnt working.....
Any help will be much appreciated.
I'm pretty sure that I had to re-code the CAN gateway when I retrofitted my MFSW. Have you had a look at this?
Thanks. Will look into it.
Any idea why the volume rocker doesn't work?
Nothing springs to mind at the moment.
Have you got a scan with your old steering controller fitted?
You should also add 77 telephone to the installation list in 19 Can gateway :)
77 - i sorted out yesterday by turning off 3 button and changing language to English. (followed THIS)
No scan from before old steering control module. Gizmo might a old one saved as i had some vcds work done by him in Feb.
Edited by Jrhoop
Here you go:
Sunday,18,February,2018,13:36:11:36443
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: TMBEF61Z2C2021***   License Plate: **11 ***
Mileage: 91060km-56582mi   Repair Order: 1
Chassis Type: 1Z-SK35 (7N0)
          77
VIN: TMBEF61Z2C2021817   Mileage: 91060km-56582miles
01-Engine -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   VCID: 79BA28B83057098C5F-802C
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Revision: 00H31001
   VCID: 79BA28B8F057098C5F-802C
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 10
                    Mileage: 90233 km
                    Time Indication: 0
                    Date: 2012.03.15
                    Time: 09:28:59
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50946
                    Count: 258
                    Count: 0
                    Count: 0
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CB431ACF7653CA444-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Revision: 00110 AC
   Coding: 48000AB8A05BB1C040100080110011E4437000AE726D8960808440040040
   VCID: 3FCE86A0AEF3E7BC21-806A
   Coding: 00D7B7
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Coding: 108002
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 43C68A50CA1B835C45-8016
   Coding: 0020792
   VCID: 3D32FCA864FFF5AC33-8068
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110616200958
   Coding: 5080140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   VCID: 77BE2E80CE431FFC29-8022
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Coding: 410E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 44C4894CCF1584647C-8010
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Coding: 351303
   VCID: 3522E4889CCF2DECFB-8060
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 197
                    Reset counter: 255
                    Mileage: 90787 km
                    Time Indication: 0
                    Date: 2012.07.06
                    Time: 00:00:03
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9807F48DF1B214A6-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Coding: 010000
   VCID: 291A38F84077790C6F-807C
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Coding: 02000402010100220000
   VCID: 3424D98C97B534E4CC-8060
3 Faults Found:
00857 - CD Changer Unit (R41)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 132
                    Reset counter: 228
                    Mileage: 90784 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 42
                    Reset counter: 12
                    Mileage: 303129 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:58:00
00862 - Antenna for GPS Navigation (R50/R52)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 303129 km
                    Time Indication: 0
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Coding: 0000756
   VCID: 48DC9D7C3B3DA00490-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Revision: 00H20000
   VCID: 3424D98C57B534E4CC-8060
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Coding: 0000756
   VCID: 47DE9E403623AF7C99-8012
   Coding: 1507610
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000023
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 133
                    Reset counter: 228
                    Mileage: 90784 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 42
                    Reset counter: 12
                    Mileage: 303129 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:58:00
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 303129 km
                    Time Indication: 0
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Coding: 0000144
   VCID: 3228DF94ADA13AD4DE-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Coding: 0000144
   VCID: 3326DA9052BB33DCD5-8066
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   ROD: EV_UHVNA_002.rod
   VCID: 393AE8B8B8D7C98C1F-806C
4 Faults Found:
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 90787 km
                    Date: 2018.02.13
                    Time: 21:08:58
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 90787 km
                    Date: 2018.02.13
                    Time: 00:00:16
13635840 - Supply voltage
          [Klemme 30: unterer Grenzwert unterschritten]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 8
          U1400 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 8
End----------(Elapsed Time: 01:17, VBatt start/end: 12.3V/12.3V)-----------
Cheers Martin.
Hopefully somebody can interpret for me....
I'd probably try  5082140000 which is your original coding with byte 1, bit 1 changed for the MFSW.
Thanks dude. Will give it a go tomorrow.
Langer's - did as you suggested and all well apart from this volume rocker.
So weird as now the mute click works but still not the volume up/down.
  • 6 months later...
I'd probably think of the the steering column control module. The controller ending with CH may solve your problem.
Good luck!
