Dangerous tyre wear on inside shoulder
Does anyone know if the Superb Sportlines (280) have camber adjustments on the rears?
  • Replies 104
  • Views 25.9k
  • I thought under inflation causes both shoulders to wear? And over inflation wears the middle?
  • Breezy_Pete
    Breezy_Pete
    I don't think I have the relevant erWin documents for this model. The wonderfully helpful fella that is @varooom may have?
  • Breezy_Pete
    Breezy_Pete
    I took a quick look at both our Polo and Fabia an hour or two ago, both of which are in spec as far as I know, for their respective rear ends. The toe in is quite visible even at a casual glance,
Items 9,10 and 11 below I believe
Great thank you.
100% adjustable on the rear end mate. I’ve had mine set up for fasst road geometry runs just under 2 degrees neg camber on the ears and I can remember toe but certainly is adjustable. Yes I do get inside tyre wear but not too bad. That’s even fine when I’m carrying some weight. I think manufacturer tolerance is 1.3-1.6 something like that
Great thank you.
