One-touch window closing?
I recently had to disconnect my battery to do some work on the car, when I reconnected it the passenger side electric window now doesn't close with the one-touch operation, whenas the drivers side does!:confused:
Does anyone have any idea why this is happening? It's rather annoying to have to hold the switch to open or close the window.
Thanks,
it need to be re-taught. I think it's press until fully down then full shut and it should then work. If not try doing a quick search on here or in the manuel
window module will probably need reprogramming , don't know how to do it though sorry , try winding the window down then up and hold finger down for a few seconds when fully up this might work
All VAG I've owned with One-Touch do this. Usually re-set itself after a full open-close.
Also, are you using thed rivers side button or passenger button?
All fine now thanks, I actually found that using the autoclosure / open with the key in the lock resetted it!!!
Thanks anyway. :)
Usually when the one touch stops, you put the window fully up, then hold the button in "up" position for 2 or 3 seconds. This restores one-touch. :)
