Passenger mirror dipping in reverse
Hi, recently I have notice that passenger side mirror (not sure if driver side mirror does it to) on my octavia 2015 from time to time "resets its position" (read: move up) so I have to adjust it a bit . Any one knows the trick?
I got the dip function in reverse enabled and works fine. Switch it is on R position.
You're in the Kodiaq forum, you might get a better response from the MkIII Octavia forum.
I can see how not having the mirror return to the position it started from being annoying though!
On the Kodiaq it works on both the drivers and passenger side door mirrors, depending on whether the mirror adjustment knob is turned to either 'L' or 'R'.
