Will these wheels fit?
Really quick one but I'm looking at some TT MK1 Ronal wheels for my 2003 VRS estate.
Diameter: 18"
Width: 7.5J
ET: 32
Planning on 225/40/18s.
I know a 17" would fit. Will 18" also fit without trouble/rubbing? I'm on stock suspension at the moment but might lower slightly in the future.
Hi there buddy!
Short answer is I don't know. I don't know what your current wheel size, tyre size or offset is. But maybe this link might help:
https://www.willtheyfit.com
Should give you an idea of what your new wheels and tyres will fit like.
Aargh. Looks like it's gonna be close. Can anyone confirm before I hit the 'buy' button? I've measured up and it looks like they might stick out just a little too far...
Again, I don't know...but I have another link:
https://www.wheel-size.com
According to this, a 2003 Octavia VRS came from the factory with
225/45 R17 and an offset of 38. Maybe compare those 2 sizes and see how big a difference it is (or isn't).
Yeah, I've used the calculator and then measured the difference with a tape measure on the car. It's really tight so need to know if someone's tried that exact size :)
Factory tyre size for VRS with 17s is 205/50/17, but many people (myself included) fit 225/45/17 instead because there is more choice and they're a bit cheaper.
@eyestwice I've seen plenty of Octavias/Golfs/Leons/Boras/A3s etc. with TT wheels before. My guess is that they should fit OK.
I've noticed some people running TT 17s so that'll be my fallback option. But if the 18s will fit...
Yes will fit with no issues.
Im surprised no one has given a definitive answer for this until now
Its the width of wheels that cause issues as rule not the rolling radius unless you go stupid.
Most Mk4's out there run 18x8's
Leon Cupra are the same,
I had a set of Porsche twists on a Mk4 with no issues 18x9/8
But then changed to a set of 17x10 rear porsche rims
General rule if it fits a Mk4 or a Bora then it'll fit the octavia
Great, thanks. I thought it would be an easy question and was surprised myself!
Easiest way to work out the rolling radius of wheels
Standard wheels 17" with 205/50
The 50 of the tyre is worked out as a percentage of the width
So in this case 205÷2=102.5
17" in metric is 432mm
432 + 102.5 + 102.5 = 637mm
18" 225/40 using the same equation
457 + 90 + 90 = 637mm
Normally you'd subtract one from the other to work out the difference between the two but in this case its exactly the same and already stated some owners run a 225 width already so no worries
Yeah, it’s the offset I was asking about. Whether they’d clear the arches :thumbup:
Offset isnt far enough from standard to make any difference. 6mm wont matter
