Stop/Start
So my Stop/Start hasn't worked in over a week in any condition
In the information screen it shows the following
https://photos.app.goo.gl/LM9HTzMPUUADDmMr9
But the A/C is not on
Checked the owners manual which doesn't help at all , basically says the same
Today it was 17 degrees not raining and the engine was hot and the temperature on normal fans on LOW.
As always if you turn off the climate unit via Menu/Off the Stop Starts works
I know it works and doesn't work under certain conditions but really
I hope it's not a battery issue
Edited by Zenbasses
You have your temperature set on "low" I can see it in the picture: that will demand the blowers to be on constantly, possibly at full speed, which in turn will not allow the engine stop start function to operate. The blowers take a considerable amount of current to run to try and maintain "low".
As the other picture shows screen says change the temperature to say 18deg or switch it off and the stop start will work.
I can replicate that all day long (stop/start not available) in my car if I set the temperature to the "low" setting.
Thanks All,
Just a bit confusing as to why it was giving me an A/C warning when the A/C was not even on...
Always assumed if it just on normal blowers and the temp set to low and the blowers basically doing nothing
Basically the setup in this photo is
Air- Con  Turned Off
'Auto' - Turned Off
Low Temp
Low Fan Speed
Interestingly over the past few days the Stop/Start has started to work again and none of the above settings have been changed its still set as
Air- Con  Turned Off
'Auto' - Turned Off
Low Temp
Low Fan Speed
This is why in the back of my mind I was worried it could be a battery issue as they can be big ££££ to replace
