@mintyflinty ive got the same ones that @Binx1310 posted a couple of pages back https://a.aliexpress.com/_EJBESM6
These lights have 3 ways of connecting to the car … tiny 2 pin (yellow) a 2pin (that looks like an E) ( blue) which is the same connector in my boot ( superb 2017) and an adapter lead to a larger flat 2pin connector that looks like an arrow shape (green)
  • Replies 5.6k
  • Views 752.9k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
@Sheriff when you changed the fuel filter did you have to do anything special??? I know on my Passats and my exeo I had to use VCDS to prime the filter but they were inline filters not “drop in “ replacements
No, just a straight change of old for new. It turned over a bit to start and then the eml light came on. Just turned it off and restarted and eml light went out. My mate reckons it was due to low fuel pressure with changing the filter. Been fine since. :)
I found this video where he primed using a code reader (edit: found it’s possible with carscanner so suspect OBD11 and vcds too) but says you can just start normally if you don’t have one.
He also has other basic service videos on superb which are handy.
Edited by Binx1310
Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays.
Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done.
thinking about fitting a hidden kill switch as well
16 minutes ago, Binx1310 said:
I found this video where he prunes using a code reader but says you can just start normally if you don’t have one.
best way is to top up canister with diesel before putting lid back on,
you'll never get any problems with airlocks
I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
Is yours a hatch? Does the hatch not have a heated rear screen?!
the rear hatch window normally has heated elements, i.e. demister.
i don't know if this was an option in some markets or specs.
