14 hours ago, Binx1310 said:
Please please please don’t write on the most expensive part of the wing mirror with tipex/paint pen….
Knowing more than one fella that deals with parts, this is to avoid writing on the "plastic paint" which is far more easy to damage, especially if you use the wrong product.
Unfortunately the pen is the cheapest option ... I got a breaker that moved to a barcode sticker type, but the adhesive sucks and it takes a long time to remove ... same problem ultimately ☠️
  • Replies 5.7k
  • Views 757.9k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
That’s true. On the paint or a sticker would have been worse!
In this instance paint won’t matter too much as I’ll be changing the mirror cap. If anyone wants a grey LHS one let me know!
On 23/11/2026 at 18:48, RogueWagon said:
Loads of plans but seem
To have lost interest now
Unsure whether to mod it because it’s such a nice car as it is
I was thinking along these lines the other day. If I bought another Superb now, what would be my essential changes based on what I have done to this one?
I came up with - Fix anything broken/tatty, Interior and exterior LED bulbs, Aluminium pedals, MIB2.5 upgrade (if not already), Start/stop deactivation module, Branded puddle lights, Spare wheel and tool kit (if not already present), Decent floor mats, some coding - especially accelerator response, reversing camera (If not already), washer bottle funnel, USB lead to arm rest, wireless carplay adaptor.
From there its then a slippery slope of more expensive upgrades which is the point I'm at now and currently resisting....
22 hours ago, Binx1310 said:
Dear vehicle dismantlers of eBay. Please please please don’t write on the most expensive part of the wing mirror with tipex/paint pen….
30 Minutes with a soft plastic trim tool and some window cleaner and it’s as good as new! I could have used a solvent on it but I dare not in case of damaging the dimming function.
I Will need to plug it in to the car to adjust the glass down to remove it so that I can swap the black mirror cap onto it. But that’s a door card off job and not one to do in the dark at 2•C!
I understood that the mirror cap can be taken off relatively easily without removing the glass?
No. You have to pop glass out then there’s 2 tabs to release mirror cap. Done it plenty of times and now got the proper vag (copy) wedge tool to make it even safer to do. But you have to told glass right down on the adjustment first which with powered ones you can’t do manually.
11 hours ago, Binx1310 said:
......especially accelerator response, ....
highly recommend getting a throttle controller like EVC, to address this.
i've got one in my Superb, been a number of years.
makes a big difference.
very easy to install.
EVC Throttle Controller for VOLKSWAGEN GOLF
A quick tea break job of replacing the broken plastic trims on the rear bench so the red flag pops up properly. Worst bit was retrieving the old broken clips so the new trims would fit. New parts from skodapartsdirect.co.uk
And lunchtime task - mirror replacement as the folding mechanism had failed on my passenger side. I picked up a whole second hand unit with glass from eBay for £49. This task also took on a couple of side quests along the way.
The main task is relatively simple - door card off, remove the tweeter holder (this is actually quite tricky as it has two catches and a peg) then remove the triple spline bolt. Obviously this was a size I didn’t have so had to make do with a t50 Torx (triple spline set now on the Christmas list!)
While the mirror was off I took the opportunity to wrap the chrome fully beneath the mirror base as I had just cut in around it previously.
Refitting the mirror is quite tricky to tuck it in beneath the window trim without catching wires etc. Once that was back in it was then over to the nerve wracking task of removing the glass to swap the mirror cap to black. Using the T10383 disassembly wedges https://amzn.eu/d/058oQqMX made it significantly easier as the width of them spreads the force out and makes it much less likely to break the glass. Then in removing the original mirror cap a couple of clips broke due to the cold weather I think. Luckily these were intact on the old mirror unit so another side quest of swapping over the front mirror frame. I warmed it slightly with a heat gun when refitting the mirror cap the second time to avoid broken clips!
With the door card off I also noticed a broken plastic rivet that holds the umbrella slot in place and hopefully the source of an annoying door rattle. This was glued back in to place before the door card was refitted.
Now all back together with a working folding mirror as well as the bonus of heated and dimming mirror glass. All finished in 45 minutes.
8 hours ago, Binx1310 said:
"Using the T10383 disassembly wedges https://amzn.eu/d/058oQqMX made it significantly easier as the width of them spreads the force out and makes it much less likely to break the glass."
oooooooohhhhhhh im telling...... you're cheating on Aliexpress 🤪
Don’t worry. More AliExpress items en route!
