Wheels
Question is how come the Fabia vrs wheels do not fit on the htp Fabia? The hub diameter and pcd are the same. Don’t understand.
What do you mean by don't fit? As in bolts don't like up? Poke out of arches?
Errrrr, is this a trick question?
Unfortunately not
Unfortunately not and it just didn’t sit flush against the hub. I’ve punched some spigot rings to see if that solves the problem.
Spigot rings? Fabia VRS wheels don't have spigot rings, are you certain that what you are trying to fit are actual Mk1 Fabia VRS wheels?
I had a set fitted on my 1.4, no issues at all and they're the same 256mm front discs as the 1.2.
